SOURCE: dacor oven ECPS127S will not heat after self clean
the problem was fixed by opening the panel between the oven cavity and the touch panel just behinf the door. you can look through the grill but to trip the reset you must unscrew the panel. you will find the reset back behind the wires Looks a red button nestled on top not very open but it should be there> i do have to say i found a step by step description on this site. but right now i can't tell you who exactly he was.
SOURCE: Dacor ECS230 Wall Oven Control Panel Time functions not working
Try turning the power off at the breaker for 12 hours.
I had the same problem, tried turning the power off for a few minutes but that did not fix the problem.
Leaving the power off overnight seems to have fixed it.
SOURCE: My Dacor double wall oven was accidentally set to
all looked after - thanks!
Turned off the electrical breaker and the oven reset itself.
good as new!
SOURCE: Dacor ECS130SCH - Both oven
If you read 0.5V with light on, then there must be something wrong, this bulbs are 12VAC.
By the way, the original part Dacor OEM 86364 is still available on the Internet, and it is cheaper than 86573. Here the part:
Ebay seller, 10 bulbs for $7.
Q10T3/CL-12V $0.41 10W 12V Replacement Lamp Light Bulb IN-STOCK
If you are not sure if a bulb has blown or not, and if the filamet does not look broken you can test the bulb using your multimeter, if the bulb reads infinity (open), then the bulb has blown.
Let me know if this solves your problem, in that case please do not forget to accept the solution.
