SOURCE: Navigon GPS
where did u get it fix because i have the same problem my green light says is on but i can turn on my screen and i also try to reset it but it wount let me do any thing
SOURCE: Navigon 5100 does not connect with GPS
NAVIGATION IS NOT WORKING. THE SCREEN IS " NAVIGON AND THE WORLD IS YOURS"
WHAT IS THE SOLUTION.
SOURCE: I've had my Navigon 7100
I solved this problem.
The backup is just a copy of the files on the SD card. I made one a couple of months ago when everything was working ok. I tried to erase the SD card so I could restore the backup manually. I ran into an error with a SD card file that wouldn't erase. I ended up formatting the SD card then copying the old backup files to it. That took care of the problem and now the Navigon works the way it's supposed to.
SOURCE: plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
