There are small sensor under the big glass that look at the size of the document to figure what size it is, well one is bad they look like little bug eye looking up at the glass. replace one or both, try below web site for rough cost if available
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Minolta cspro ep2010
Do you have two trays or four trays for the paper? If you have four and the display is showing the bottom door is open... turn the copier off and disconnect the bottom two trays and turn it back on..... Just use the top two paper trays.. Or the problem is that a acturator is broken off the side door, look for any broken pieces of plastic. Also, recheck for any jamed paper left in the copier.Good Luck
SOURCE: minolta 1080
how the code appeared?
I suppose you worked with the cyan low toner attention untill the machine stopped. in this case you should make an ATDC sensor adjustement! but firstly you should reset the error!
SOURCE: MINOLTA EP2010 CSPRO ERROR CODE C04, WHAT DOES IT
MINOLTA EP2010
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
SOURCE: My Minolta CF1501 is showing error COF 34
Before doing above open and close the front door. The code is for the Auto Toner Density Control the black image unit if it comes back after opening and closing the front door the image unit needs replacement. You can't change the developer it is all one unit. the fuser has a different code 500 series. Dont mess with gain let machine run stablize.
i have minolta ep2010 it is showing error cof e8, how can i solve this
