Can't get IF to work on my night vision monocular
There are only 6 versions of night vision showing, it sounded like you said f5, but the only one that looks like yours is a FT 300.
This requires a 3V lithium battery, you must make sure it's lithium .
Duracell D/L 1/3 N , radio shack 23265, Eveready 2L-76.
Here are the instructions, '
To use, depress the Energizer button, and release. A gradual fading of the image is typical. Press the Energizer button again to re-power. If your unit includes a self-energizingpower source (i.e., does not require batteries), simply depress and release the top lever one time and repeat as necessary.3.The infrared (IR) illuminator works to enhance the available ambient light in areas of extreme darkness, or brighten the electronic image in very dim ambient light. Utilize as needed by depressing the IR button (next to the Energizer button onmost units). Also, please note that on self-energizing units only, the detachable IR illuminator requires a 3-volt lithium battery.
Let me say that this is not a IF, infra red, Infra-red picks of heat from the environment, so when you look at something say a person you see their body heat, they cost thousands.
This is just a night vision, it does not even say what GEN this is.
There are three GEN's, GEN 1, GEN 2, GEN 3.
GEN 1 is cheap, GEN 3 is expensive. Starlight is the best, but your looking at spending 3000,00 for a good one.
Don't expect this one to be that good.
Here is the manual.
http://www.famoustrails.com/downloads.html
If it does not open, or can't download, then download foxit reader, it's free and allows you to view PDF files online.
