SOURCE: Delivers only small amount of coffee per brewed cup
Same problem happened to me. There is a plastic boot inside the tank that is broken. This seals the top to the tank to the center rod. Keurig will not sell me the $5 part. They would would be glad to sell me a new brewer though!
SOURCE: water not coming through when brewing...just drips
clean hole where coffee comes out with smsll brush
SOURCE: MY b60 all of a sudden won't fill a full cup when
When I descaled my b60 I also used a paper clip to clean out a possibe clog in the little bottom drainage tube. The help I received suggested I also use the paper clip to check the top tube which I didn't know about. I did this and now it works fine...thanks for your help.
SOURCE: Won't brew the full almount of coffee for the
My brewer is new. Only used it 5 or 6 times. It only dispenses about 3 oz of water. What is wrong?
SOURCE: My Keurig coffee maker is not brewing the size cup
Hello. I recommend that you descale your machine. Here is how to do it: http://www.keurig.com/help/De-scaling_instructions.pdf?mscsid=27SCSLLH993M9P2RCE7EGD5S1AK660A1
Please reate my answer as very helpful. Thank you. Joe
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage.
