Hey, I'm Seth. I work as a sub contractor for dish network. I am picking up that your problems are on TV 2? If so, you will need to go into the menu on the TV itself and look for, "channel scan" or "auto memory". Run a scan. If there are no channels found go back to the "channel scan" screen. You will see an option saying, "air" or "cable". Switch it to the opposite of whatever it was previously on and run another switch. It should be found. I hope this wasn't too confusing, good luck.
Hey murphypat321,
Sounds like the TV may need to be on ch 73 cable rather than 60 air. Try switching the TV to 73, if it goes to 69 then put back on 60, if goes to 73 good. Once you have that set go to your TV1 and bring up the menu. Go to System Setup (6) -> Installation (1) -> Modulator Setup (5) and change the TV2 setup to either cable if on 73 or air if on 60 and the picture should come in if everything's hooked up.
Hope that helped! You can email me at [email protected] if the problem persists.
Tommy Faust
DISH Network
murphypat321, the ANT IN spot on a TV is for like an actual TV antenna. To use a Coax cable on a TV you would have to run it to a UHF/VHF/CATV IN.
What outputs are available on your TV, and the other one you can hookup that works? Have you tried using component/composite cables in place of coax and using an input?
Tommy Faust
DISH Network
Sorry, I left something out of the previous post. If ANT IN is the only spot on the TV, try changing the modulator setup to 73, and the TV channel to 73 instead of 60.
