Televison & Video Logo
Posted on Mar 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i've just had my computer ugraded to windows 7 but i cant play my sims 2 it keeps saying that i need directx 9.0c compatiable graphics adapter for it. but it was playing on my windows xp fine untill i upgraded it i've gotinstalled on my computer at the moment is Standard VGA Graphics Adapter please help driving me mad :(
Anonymous
Level 2:
New Friend:
  • Expert 56 Answers
  • Posted on Mar 09, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
56
Questions
0
Helped
6484
Points
186
The error message is correct. Windows 7 is not backwards compatible with certain graphics adapters requiring DirectX support higher than 8.0.
You should attempt first to install the proper driver for your graphics adapter from the manufacturer, and if that does not fix the issue, you should either install a new graphics adapter, or revert back to Windows XP.
jacob
Level 1:
  • Contributor 26 Answers
jacob
Contributor
Level 1:
Answers
26
Questions
0
Helped
5117
Points
80
Windows 7 takes more resources to run with the same programs that windows did. I would upgrade the video card. Most cards that support directx9 are sold on popular websites for about $20
Can't play games after windows 7 install
Have you installed the latest drivers for your video card ? Because in your description you are running with standard VGA drivers from operating sistem. Find your laptop model and visit the manufacturer support site and see if they have driver for Windows 7. If not try to use Windows update from Operating Sistem, from Start menu - Applications - Windows Update.
1helpful
Computer Keeps RESTARTING when ATI video driver installed
weve got the same prob.i also try what you did on your pc..but nothing happen but when i put a new graphic card it fix everything..try this..buy a new graphic card,
2answers
WHEN I LOAD SIMS IT TELLS ME THAT IT CANT FIND THE DIRECTX9.0C COMPATIBLE GRAPHICS ADAPTER. WHERE CAN I DOWNLOAD ONE?
Graphics adapter its hardware device rather then software. You check whether all driver installed for you video card and DirectX9.0 installed too. It might that you poses old video on board card which doesnt support directX 9
The graphic organizer won't work it says i need DirectX 9.0c
First thing you do is check your system requierments,(should be located on the back of your CD case, or somewhere in your manuel, probebly under the title "System Requirments") it will probebly say something like "complete Direct-X compatible graphics adapter requiered". You then go to Start Menu-->Run (type in "dxdiag" (without quotes)) and see if you have the correct graphics card, and or graphics adapter.
If you do have the correct system requierments repost your problem saying you have the correct system requierments but you still get the following message: "Failed to find any Directx9.0 compatible graphics adapters in this system! Please make sure you have a DirectX 9.0c compatible graphics adapter and have installed the latest drivers provide by the manufactuer. The application will now terminate."
If you do not have the correct system requierments, you cannot play the game on that computer.
Hope this helps.
Levi_xx
Cant play sims2, message pops up saying i need Directx 9 adapter.
of course we need the specks Taylor- and your graphics card should support directx 9. Unless you have some obscure onboard graphics card or are running win 98 or ur card is really old direct x 9 is supported by cards that were sold even 3-4 years ago.
NOW WHAT YOU CAN TRY IS: If you are on win xp and this funked up message shows up you can try running the gave in compatibility mode for win 2000. right click on the game file go to compatibility tab choose win 2000 in the dropdown apply and okay it. Try and run it again.
Cheers
rate if this does it- if its your low end hardware upgrade coz there is nothing any of us can do for low end hardware
Direct X compatibility issue with new graphics card
Hi tom2badcat, the SIMS game is very picky when it comes to graphics cards. If you look on the SIMS box you'll find their recomended graphics card list. The video card you bought is a low end 8x AGP card. You can try downloading & installing directx 9.0c from microsoft. Click on this link;
http://www.microsoft.com/downloads/details.aspx?familyid=9226a611-62fe-4f61-aba1-914185249413&displaylang=en
If directx 9.0c still fails to install the graphics card is at fault & you should return it. Listed below is a link. The link provides a couple 8x AGP graphics cards that will run both directx 9.0c & the SIMS expansion pack 2. (The graphic cards shown all use faster memory).
XFX cards carry a lifetime warranty. (No# Choice)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1776106&CatId=318
Below is a whole list of 8x AGP cards.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&name=AGP&
Brief Description:
November 2008
The Microsoft DirectX® End-User Runtime provides updates to 9.0c and previous versions of DirectX — the core Windows® technology that drives high-speed multimedia and games on the PC.
2helpful
How to download ms directx 9.0 compatiable display adapter
From the sound of the error message your video card (sometimes called a display adapter) is not directx 9.0 compatible. Unfortunately this can not be fixed with a simple free solution. The only way to solve this problem is to purchase a new video card.
1helpful
Directx 9.0 graphics adapter problem
plz unistall the graphic card drivers and reload it, post your findings
Direct x
you can download this from www.download.com or DirectXwww.microsoft.com/windows/directx/default.aspx
Top Compaq Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Compaq Televison and Video Expert? Answer questions, earn points and help others
