Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
I had the same issue with my Siemens W725TC. Basically, you need to remove the batteries from both the door chime and the push button unit. Leave for 10 seconds and then reinsert the battery into the push button and then the batteries into the door chime unit. The door chime unit will then synch itself back with the push button unit. Worked for me, so hopefully it does the trick for you. Also, if you find your door bell starts ringing for no reason this is because it has synchronised with another door chime unit (ours linked to the neighbours across the road so we always knew when they had a visitor - lol). Repeat this process and it should sort out the problem.
This is brilliant. My door chime stopped working too so I tried this and it worked! Thanks
Just buy a new one...tight wad!
