SOURCE: Kenmore Dishwasher leaving SAND behind
1. Remove the top rack and lower rack.
2. Remove the lower spray arm by holding the top of the center hub and rotating spray arm counter clockwise.
3. Remove water tube feed from the back wall of the dishwasher by unclipping at top and back. Pull towards you and lift tab at the bottom on the big tube to remove the plastic clip from main water feed.
4. Remove the main water tube by turning quarter turn clockwise, then lift off. Keep the center hub from falling out so you don't lose the plastic washer.
5. Using a star tip screw driver; remove the four screws and lift off the filter cap assembly. The assembly consists of the screen filter and the food trap grate (The outer edges look gear like).
6. Look down inside this area and clean out anything foreign. usually there will be seeds, paper, and other gook. I used tweezers, toothpicks, and needlenose pliers. I remove from my dishwaser quite a bit of paper, two wooden match sticks, lots of undissolved soap etc.
7. When you have removed as much as you can, put everything back together in the order you removed it.
8. When you run the next cycle, you should immediatly hear more noise to indicate that you have cleared the pathway that allows water to flow at its intended pressure.
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
replace the top spray arm and it should work ok again
SOURCE: dishes still dirty after heavy wash cycle
There is a screen on the drain area of the bottom of the dishwasher that needs to be cleaned. It has a plastic mesh screen on it - you can't miss it. Second get an old toothbrush and clean out the little jets on the washing arms that spin around. You will notice these holes are clogged up with calcium deposits etc. Those things done you will have a new dishwasher again. You need to do this every 6 months or so. Also use a rinse conditioner for a while to assure the jets are clean. Good Luck
SOURCE: My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
SOURCE: Kelvinator kd14ss
This is a common problem with this machine. Per the manual E4 indicates that the machine is overloaded but this is incorrect. The machines has actually become water logged due to a design fault whereby some water is allowed to pool at the bottom of the machine rather being efficiently drained. Note that the area where the water pools is not rust resistant. To temporarily overcome the E4 error, tilt your machine backwards and the excess water will drain out the back corners. Remember to put some towels down to avoid a big mop up operation afterwards. I live in a coastal area so drain the machine this way once a month and then open up the back of the machine (don't do this if still under warrantee) to dry it out completely to minimise the rust.
