Fuji FinePix F10 Digital Camera Logo
Posted on Mar 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My outdoor pictures are very very pale, almost white with stripes across the entire photograph
Anonymous
Level 3:
  • Master 639 Answers
  • Posted on Mar 09, 2011
Anonymous
Master
Level 3:
Answers
639
Questions
Helped
135178
Points
2076
Too much bright when you taken the picture, try to turn off the flash light when capture outdoor or in bright room.
Hope this help.
5helpful
2answers
Our tv has several white spots blocking out the picture on the tv, what could be the issue?
This problems very exspensive to fix.The Light projection Engine have a problems,with a IC design flaw.This problems happen to many Big screen tvs 65 and up have a design IC flaw by many companies like Sony,Mitsubishi,Toshiba and Samsang.Call up Mitsubishi make some kind of deal with them to help u to fix the Light projection Engine by replacing the IC or replace the whole entire Light projection Egine.
White surfaces photograph pink in color with
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
1helpful
Toshiba eStudio 2830c-getting a light line across
Hello sir; Is the stripes allway in same place and you use document feeder to copy, then you have to clean up a piece stripe glass on the plateform, otherwise ,you have to change drum cleaning blade or drum cartridge.
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
8helpful
I cano not take outdoor pictures its all white
shutter is sticking so it over exposes photos . will need shutter or lens assembly replaced. it will have banding stripes in low light and white in bright light.
Lines appearing across printed photographs
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Striped pictures
The sensor chip on which focused light falls has a failed connection. The image is 'read' via a matrix that is scanned to retrieve the image and one of the paths of this matrix is broken.
Crt tv screen is pale
what model set do you have. Sounds like the green crt or drive circuit. List the model number and I may be able to help you.
Stripes
This is caused by a stuck shutter. Since the camera is under a year old it is still under warranty.
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
