The tv's hdmi connection is an INPUT, not an output. to get tv sound through hdmi, you have to connect the hdmi OUTPUT from a dvd/blue ray or a cable/satellite box. your tv may have digital audio out on a seperate jack, possibly a fiber optics connection, which you may be able to run into your stereo. however, most tv's do not have audio outputs, you have to get the audio signal from a disk player or cable box 99% orf the time.
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
