SOURCE: I have a kenmore mini-fridge
they do that when they are on the way to the big kitchen in the sky. sorry, but mini fridges do not typically last very long.
SOURCE: my frdge compartment is freezing
Pehaps the damper door motor is burned out or the damper door is just stuck open causing to much air to flow into fridge side. Damper door is located at the very most top-back-left corner of the "fridge" side.... goodluck...
SOURCE: FRIDGE COMPARTMENT FREEZING
try this,make sure you dont have anything blocking your blower in the freezer.if that is okay if you have seperate controls for the freezer and the fridge,try setting the frige setting lower and the freezer higher,this makes the blower work more in the freezer.hope it helps.
SOURCE: F&P E402B Active Smart Fridge Compartment not cool
You need to start with a clean totally defrosted unit. That means clean, vacuum and wipe as much as you can around the entire motor compressor area especially any coils you can reach. Then set temp around whatever normal is and see what happens. If still the same it's time to have a tech do pressure tests.
SOURCE: Both freezer and fridge Not cold on top
sounds like the circulation fans are jammed/seized or faulty -try a full defrost and see what happens after that.
If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
