The problem is under your hood, there is a rubber that guides the water out, and gets plugged with whipper wheel, leaves etc, lift yours up and clean the debris out of it so that the water can drain, Then your mystery soaked carpet issue will be resolved.
Shop vac the carpet dry then spray garden hose around both rear doors or around doors and see if you get wet or see a leak. Also spray under vehicle on both sides of car and check for leak.
