Sony VAIO VGN-NR120E/S Notebook Logo
Posted on Mar 09, 2011
I want to connect my Sony Vaio VGN-NR120E to my TV Samsung. But I have no idea how to do that. Could you give me advice ...
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Mar 09, 2011
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
6027
Points
60
Your Sony vaio does not have any TV-out port to output the display on any analog TV. You can use your VGA (by using VGA cable) port to output your laptop on LCD / Plasma / LED TV (with a VGA port also)). If you still want to project to analog TV via the VGA port, you need to find a VGA to RGB adaptor. But bare in mind, it's hard to find one.
VGA port is like the port on computer monitor. RBG consist of three colored port.
Good luck ;)
1helpful
How do I replace the hard drive on my sony Vaio VGN-NR120E?
To replace a hard drive, you'll need to backup any data you want to keep, uninstall the old hard drive, install the new hard drive, and then restore the backed up data.
The specific steps necessary to replace a hard drive differ depending on the type of hard drive you're replacing.
Need to locate the re-set button on a sony vgn-nr120e laptop
Hi
What are you trying to reset if you go to the add comment just under this box and post up what you are trying to do hopefully someone can help you
look forward to you repost
Sony vgn-nr120e stops working
Uninstall unnecessary softwares from add/remove programs. Did you noticed that cpu fan is working? If not then clean the cpu exhaust system with blower and also check the cpu fan function in BIOS. When using laptop always use flat surface to place it, mattress or sofa create problem with cooling and exhaust system of the cpu fan.
Hope this will help you.
Regards;
Hasan
Sony VAIO VGN-NR120E/S PC Notebook not powering up
ur boot files are being corrupted either there is a trojen or a virus that's preventing the Win from working.
do this...when u switch on the machine press F8 function key and try to load in Safe Mode. if u can do that then get Tuneup Utility from my website (download page) www.sureshayyar.110mb.com
install and run the cleanup process...1n click maint in that does a good job...use all the tools in that and get ur machine to working....
else u need to boot from a Win CD try do a repair of ur OS....
else let me know...we go to plan B
Is the sony vaio vgn-nr120e a 64-bit?
Hi, the processor of the this model Vaio is Intel Pentium Dual-Core T2310. This is a 64bit processor which means that it should support a 64 bit operating system. Whether it will come with a 64 bit operating sysem, depends on your order.
Here are two links with the processor specifications and the Vaio specifications:
http://ark.intel.com/Product.aspx?id=32431
http://www.clearanceclub.com/products/8959-VAIO-VGN-NR120E-S
If you already have one, you can check if it is a 32bit or 64 bit by clicking on: Start/right click Computer and select properties.
Regards,
Purito
2helpful
Sony Vaio VGN-NR120E cracked lcd screen.
You won't be able to see video if your LCD screen is cracked.
Connect a monitor to the VGA port , the hold the Fn key and hit F7.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
