Depending on type of work/wood the finer the nail, results in increased jams. Eighteen gauge and finer experience more jams than say 15 gauge. Fine gauge nails also suffer from square cut tip. I believe that if the nails were pointed (like Senco nails ) they would more likely drive true. Jaming can be decreased by selecting the correct nailer for particular work. Dimentional lumber and hardwoods tend to increase problems compared to quality plywood or non wood trim materials. If you experience jaming with any type of wood then time to look at driver for possible problem. Check driver for bent or worn tip. Driver blade can be dressed square on grinder. Some drivers have a slight angle/taper ground into tip on the side that faces the rails. This taper continues up the blade about 1/2 inch. The taper will prevent the driver from hitting the second nail. On really hard woods, try drilling a fine pilot hole to produce best results. Good luck
