Question about Lexar FireFly 2GB USB 2.0 JumpDrive
I pulled my 2 GB JD lexar firefly out without ejecting, and it says that all my files for school (including a massive AutoCAD final project) are gone, but the amount of space they take up still shows when i right click on the drive and choose "properties." Is there anything I can do to recover the data or do I need to re-do my final project in the week that's left before it's due?
    New Friend:
  • 21 Answers
You can recover the data by steps blow
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download data recovery software, recommended one is asoftech data recovery (simply because i was using it and it worked)
http://www.asoftech.com/adr/
4. Install and open asoftech data recovery program, select your memory drive, and click 'Next' button to start scanning process which will find your data.
Posted on Nov 22, 2012
    New Friend:
  • 21 Answers
Yes,you can easily recover data by using a data recovery program.
Try this one called Tenorshare Data Recovery. It can recover data after deeply scanning your hard drive to look for lost data.
You can get it here: http://www.any-data-recovery.com/
Posted on Apr 06, 2011
    Novelist:
  • 241 Answers
Don't be so worried about ur data. There are some gud data recovery software available on internet. But first of all please stop using d drive anymore to increase d chances of recovering files. Then you need rely on professional data recovery tool. Download the software from the following sites http://www.recoverdeletedfile.org and follow the steps
>. Install the software on ur computer.
> Connect the drive to computer.
>. select the drive(usually G or H for external drive) , click Start. Now the scanning process will start to search the deleted files. After a while you will then get a list of recoverable files.
>. Press Recover to perform full recovery.
Posted on Mar 16, 2011
    New Friend:
    Problem Solver:
  • 16 Answers
That's why one is always asked to remove its drive with the "Safety Remove Hardware" tool. So, I hope you can learn a lesson to remove all your drive safely after experiencing this trouble.
But, now, in order to get back your lost data, you can try a drive data recovery freeware that has ever successfully retrieved all the inaccessible data of my friend off from his formatted WD drive. It is really worth trying.
Try to download it here:
http://freeware-fix.blogspot.com/2013/02/hard-drive-recovery.html
Note: Before the data recovery process, you'd better not save anything else on this drive in case that any new file will rewrite your original files.
After the data recovery process, you also do not save the restored data on the same drive in case of data recovery failure.
Posted on Sep 24, 2013
    Sergeant:
  • 236 Answers
Your description of your present situation seems to be promising. If so, you can try a couple of free data recovery softwares that you can download off from the internet. (1) EASEUS Data Recovery Wizard Free Edition, or (2) Recuva. Though these programs does not promise full data recovery, it is capable of showing you what can be recovered and what cannot be. Assuming that your files are still intact even from what those files went through, this way, you may have a chance to retrieve your files. Both are user friendly and has an online help.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Posted on Mar 09, 2011
    New Friend:
  • 74 Answers
Hi brymbyl,
You can try running scandisk on the said drive so that Windows will try to recover the data. You can do it by going to Computer window, right click the jumpdrive icon, click properties, click tools tab, click now then tick the check box for "automatically fix file system errors"
I hope this will help you.
Regards,
Ben
SOURCE:
How to format Lexar JD USB
Insert the flash drive in a USB slot and see what drive letter gets assigned to it. Right click on the new drive letter and select format from the drop down menu. Follow the directions on the next screen to format the drive.
Aug 23, 2014 | Lexar FireFly 2GB USB 2.0 JumpDrive
I have a lexar jd firefly 2gb usb and I dont how to install a driver for it?
go into system,go into devices which shows what is fitted to computer,if theres a yellow mark over the lexar unit press reinstall drivers
Jun 30, 2010 | Computers & Internet
I have a lexar 2gb jd firefly usb drive and i dont know hoe to install the driver for it. Please help me!
You don't need to install any drivers for it, windows should detect new hardware and install the drivers that it already has for it. If your system isn't detecting new hardware when your plugging it in, then you might have an issue with your USB ports on your motherboard. If thats the case then go ahead and try hooking up like a USB keyboard or USB mouse. If it recognizes those then you know your ports are fine.
If your ports are fine and your USB firefly drive isn't being recognized, then your USB firefly drive is bad.
Got old toshiba laptop to use as portable graphic runs windows98
Your old Toshiba laptop most likely does not have a firefly port.
The only way to use your firefly device on the Toshibe is to purchase a firefly PCMCIA adapter card and plug it into the Toshiba's PCMCIA slot and install the card driver.
Please click on this link for details and prices for this adapter :-
http://www.firewire-1394.com/cards-firewire-laptop-notebook-cardbus.htm
Jun 14, 2010 | Lexar FireFly 2GB USB 2.0 JumpDrive
Storage issue LEXAR Firefly 4GB
Empty your "Recycle Bin", to permanently detect some "hidden" files on the JumpDrive.
If necessary, try a "quick-Format" to reformat the drive, deleting all "hidden" files.
Mar 03, 2010 | Lexar FireFly 2GB USB 2.0 JumpDrive
I deleted all the viewable files and folders on my lexar firefly jumpdrive, but it says that i still have almost all my memory used up. how can I clear it?
You may have hidden or locked files. If the files are locked, you'll see an icon to unlock them when you open the JumpDrive in Windows Explorer. If the files are hidden, try and show them: Tools-->Folder Options-->View--> Left Click "show hidden files and folders" Good Luck!
Jan 05, 2010 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
I dont know how to save a writing piece from the word pad onto the lexar firefly
Open Wordpad, click File-->Save As; type in your desired name for the file and click the pull down arrow near "Save in:". Select the appropriate Drive (G/D,E or whatever) that is your Firefly. Click save. The file should now be saved as a Rich Text Formatted document on your Firefly. You can save it as a Text Document as well under the "Save as type:" option. Good Luck!
Oct 20, 2009 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Lexar firefly 1GB Jump Drive - Can't copy files to jump drive
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format pendrive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Dec 28, 2008 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Lexar FireFly 2GB USB 2.0 JumpDrive Logo
618 people viewed this question
Top Lexar Electronics - Others Experts
Ekse
Joe Negus
Joe Negus
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
