HP Officejet 4215v All-in-One Printer Logo
Posted on Mar 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blinking orange exclamation light next to the on button... ldc screen reads cartridge error see product documentation
Anonymous
Level 3:
  • Master 600 Answers
  • Posted on Mar 09, 2011
Anonymous
Master
Level 3:
Answers
600
Questions
Helped
282413
Points
1231
Have you downloaded any HP software lately, I did that and made my printer in to a doorstop! HP said tough????
Why does exclamation point orange light flashing on HP Officejet 7110?
The lights on the front of the HP product can be on, off, or blinking (flashing), depending on the status of the product. The lights indicate product status and are useful for diagnosing printing problems.
For more read... HP Support document and HP Tech Support .
Thanks,
3answers
My hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
There is a green blinking canister next to the power reset button and next to it is an orange light with an exclamation point. What is this indicating?-
Its an information / error led . It says server hardware has encountered an error. Find device that has error and replace it if required .
You can see a similar orange color on device that has error .
Check these parts for orange color .
1: SMPS
2: Memory
Thanks
2answers
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
I have a Lexmark X2690 that came with my PC (HP Pavilion Labtop) in July 2008. I hardly use it, but, when I do, I am always unable to print, most likely due to one or more of the following errors that I...
The light indicates either a paper jam or a problem with your cartridges (probably due to low ink or faulty). To identify and fix this issue, please follow the steps below:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
  4. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
  5. If cartridge area is clear, close the cover.
  6. Unplug and re-plug the printer into the power outlet to reset it.
  7. When the printer turns on, reinsert one cartridge first.
  8. Close the printer cover and check for any errors.
  9. If no error appears, reinsert the other cartridge. Close the printer cover.
  10. Replace whichever cartridge is causing the error to appear with a new cartridge.
  11. If there's no indication of any problem, try to print a document again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
I can't print and I have an orange flashing light on the right side of the printer. Whay does this mean?
Issue: The Power light is on and the Resume light blinks
In this error condition, the following light pattern displays on the product control panel:
•Print Cartridge status light : Off
•Resume light : Blinking (orange)
•Power light : On (green)
Causes
??¦The product is processing a print job, or waiting for the ink to dry on a document.
??¦The product might be out of paper.
??¦The product might have a paper feeding issue or a paper jam.
There are several possible solutions. To work through these suggest you follow the illustrated on-line guide found here.
Have a deskjet 710c inkjet printer the inks seem to be stuck over to the right and the 2 orange buttons are blinking. ... * Solve It! Solve It! Bid * * * ... have a deskjet...
I found this on the HP website. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09179&cc=us&lc=en&dlc=en&product=59307&tmp_track_link=ot_search
POWER light On c00106963.jpg RESUME light Blinking c00106965.jpg PRINT CARTRIDGE light Blinking c00106961.jpg Problem
The BANNER lever needs adjusting.
Solution
1. Turn the printer off.
2. Move the BANNER lever (next to the paper tray) up and down a few times.
3. Turn the printer on.
If these solutions did not fix the problem, have the printer serviced.
2helpful
Print cartage problem black
i believe the orange exclamation mark button is blinking
please follow the document and this should resolve the issue hopefully :
1.disconnect the power cable from the back of the printer
2.pressa nd hold the power button for 20-30 seconds
3.reconnect the power cable to the printer
4.power onn the printer
5.if still its the same issue
try the steps from the below mentioned URL:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01887242&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=3645100
then try this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443507&tmp_track_link=ot_recdoc/buu00657/en_us/c01443507/loc:1&lc=en&dlc=en&cc=us&product=3645100&lang=en
if still nothing happens
try with a new set of ink cartridges and if it works call HP toll free number and they shopuld probably replace the cartridges for you if the cartridges are in warranty and they have sufficient ink in them and even after replacing the cartridges the printer does not work they should replace the printer if the printer is in warranty
HP TOLL FREE -1800-474-6836
thanks and regards
hope this fix the issue
Hamid
1helpful
2answers
Cartridge error -
FRIEND THIS PRINTER IS IN RIGHT SIDE next to LEVERS OF BLUE CARTRIDGE TWO SMALL LAMPS ARE sensors, if they are dirty TONER WILL MAKE OF THIS MESSAGE.
2answers
Cartridge error
Please first check whether there is paper jam in the printer roller or else please check the cartridges is fixed properly
k24674
Grand Canyon Tech
Grand Canyon Tech
