When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
support-us.samsung.com/.../pop_troubleshooting_fr... Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08 Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
These little units should be pretty straight forward. There is a little collection bin for the water that has to be emptied in order for it to work. Make sure that is emptied to start with and as you run the unit you will have to empty it periodically when full or it will only blow with the fan. Hope this helps YAFIXIT 2RNS4U (
I was told the filter needs to be cleaned. Turn the air conditioner OFF and unplug it.The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter. After cleaning, replace the filter and plug the air conditioner back in. Hope this helps :)
