The Panasonic SB-WA733 is an active subwoofer that was originally sold with the SC-HT733 Home Theater system. There is no AUX input on the SC-HT733. (The manual for the SC-HT733 available online covers three models. Only one, the SC-HT930, has an AUX input.) With the original remote for the SC-HT930, the remote has a TV/Video Aux button. The SC-HT930's Input selector button (to the right of the power button) will add an Aux option when you cycle through all of the available inputs. I found the manual for the SC-HT733 at Manage My Life here: http://www.managemylife.com/mmh/lis_pdf/OWNM/L0532709.pdf .
Which home theater system do you have? Check the input to which you have connected the audio cable; set the unit to that Input to hear your music.
I hope this helps. Please add a comment with the model number for the center part of your audio system for further assistance.
Of the Phillips is not a home theatre system them you can but you will have no volume co trol of the sub. If it is the alot of philips home theater in a box (htib) use special plugs...you would need to change the cable end of the sub to a compatible plug.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
There is a subwoofer outlet at the back of the sa dp1 connect via cable to the inlet on your sub then on your sa dp1 remote press shif and subwoofer at the same time
