Question about Polycom IP 501 MGCP IP Phone
My polycom phone ip 501 stuck in reboot cycle. It shows error of 0X4020. When it reboot it shows 3 option.\r\n 1) reboot in 10 seconds 2) set up 3) about I tried all options but it doent work and shows error 0x4020 ( config file error). How could I can get start my phone normally??
SOURCE:
SOURCE: Polycom Soundpoint IP 501 - URL call is disabled
I get this same problem. The phone icon turn white and "url call is disabled" I can place calls and receive incoming calls, but cant place outgoing calls, unless the phone is rebooted
Posted on Jun 01, 2008
Junoon007
  • 1011 Answers
SOURCE: Polcom phones stop ringing
Dear Sir/Madam,
1) After rebooting you can watch your ftp server and see the phone logging in and logging out. Its doing several things (checking the size of the bootrom.ld and sip.ld files and seeing if an update is necessary, etc etc) that I will go over later. It will reboot a couple of times to finish off the update.
2) After the reboots, lets be absolutely sure and lets check the bootrom and SIP versions.
  • Press the Menu button, 2 Status, 1 Platform, 1 Phone. Arrow down to view the BootRom version here.
  • Press the Menu button, 2 Status, 1 Platform, 2 Application, 1 Main. You will be able to view the "Version" number here.
If you did everything right, you should see the latest versions of the bootrom and SIP app that you had placed on your ftp site.
Now check your FTP site. You will notice that there are files being uploaded to your directory with *.log extensions. You guess it, these are just logs that the Phone dumps so you can trouble shoot when need be. If everything was done right, your phone will of seen the new bootrom.ld file and downloaded it, rebooted, and installed it. Next it will download your new sip.ld file and use it.
For More Information and Software updates. See this link.......
http://www.voip-info.org/wiki/view/Asterisk%40Home+Handbook+Wiki+Chapter+7#7224HowtouseProvisioningCentralBootServe
Thanks
Good Luck
"Don't forget to rate the Solution"
Posted on Jun 28, 2008
SOURCE: just installing polycom 501 phones with nextiva
Ohh this mean, you did not register this extension on your phone system. Create this extension on your phone system. Be sure that password given on Phonesystem is also configured on phone too.
Posted on Nov 14, 2008
corydzbinski
  • 7 Answers
SOURCE: failed to get boot parameters via DHCP
You didn't provide any information about your network which is ALWAYS required to provide any type of help, not to mention a solution.
"Failed to get boot parameters via DHCP, xxx seconds until reboot" simply means that the computer isn't getting an IP address from your router. Setting up your router is another entirely separate topic.
This is pretty simple though, one of three things is happening:
1. Your router is not properly configured to provide DHCP to the phone.
2. Your network cable is bad.
3. Your phone is bad (most likely the RJ45 port since the phone seems to work otherwise).
You can check for bad ports or cables by checking the port status within the router. If the port is lit up, most likely the cable and phone port are fine. This is not 100% though, replacing the cable should always be a consideration even with a lit port.
Posted on Jun 04, 2009
Testimonial: "thank you"
corydzbinski
  • 7 Answers
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Posted on Jul 02, 2009
Polycom IP 501 won't reset to default when using MAC address as password
If your phone isn't on a constant reboot cycle and can boot up, then go into Admin Setting and do a Format File System reset. NOTE: Only try this if you know how to download the software files onto the phone via FTP server. Once you download the latest software your phone should be almost as good as new.
Sep 19, 2012 | Polycom SoundPoint IP 501 IP Phone
go to this website and go to customer support www.polycom.com
Jun 24, 2008 | Polycom SoundPoint IP 501 IP Phone
I have a problem regarding my Polycom Soundpoint IP331. It doesn't boot anymore. It shows only an error which is error.cfg.
You need to reinstall all the files back onto the phone. You can get the files from the Polycom Website. You can also follow the instruction from my Polycom 501 Fixya blog to see how its done.
Jun 15, 2011 | Polycom SoundPoint IP 501 IP Phone
Polycom 501 phone keeps trying to reboot itself. We rebooted manually a few times and get the same error message: 'Could not find boot server current configuation" Any ideas?
try to turn off the Polycom device. When you turn it back on, press Setup. from the options, select server then click edit. Then select the item Trivial FTP (that setup depends on your ISP), and type the IP address assigned to your network (example 192.168.90.90) then hit OK. click exit several times then press Save & reboot. If it did not work, let us know...
Jun 19, 2010 | Polycom SoundPoint IP 320 SIP IP Phone
Can ping my polycom 501 but cannot open with my
Have you tried a factory reset from the menu interface? Be careful if you do, and only choose "Format File System" as a last resort, and only if you feel comfortable enough setting up a FTP/TFTP boot server to re-provision the phone, as this option will erase everything, and then all it'll do is get stuck in a boot cycle until reprovisioned.
Feb 22, 2010 | Polycom SoundPoint IP 501 IP Phone
Apr 10, 2009 | Polycom SoundPoint IP 501 IP Phone
Polycom ip501f error, application is not present
Make sure you have the latest BootROM and SIP config files for this polycom(sip.ld, sip.cfg, etc...) on your TFTP server. If you do not have this - download from here - http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip501.html
If you do not have a TFTP server, you can download one for free.
Dec 04, 2008 | Polycom SoundPoint IP 501 IP Phone
Dead Polycom 501
u have the cable plugged in backwards
check it
Jul 25, 2008 | Polycom SoundPoint IP 501 IP Phone
Jan 08, 2008 | Polycom SoundPoint IP 501 IP Phone
Polycom IP 501 MGCP IP Phone Logo
Top Polycom Computers & Internet Experts
N8nNc
Tom Chichester
Dayton Computer
Dayton Computer
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
