Casio AW81 7 Data Bank World Time Watch Logo
Posted on Mar 08, 2011
My watch is silent after replacing the battery.
Straussburg Manor chime clock doesn't work even after replacing battery. Any tips to troubleshoot?The clock was obtained via auction. Tried manually swinging the pendulum, but it always stops.
Troubleshoot the issue. Here are some steps you can take:
Check the Chime Selection Lever:
Ensure that the chime selection lever is not set to the "silent" position. Sometimes, accidentally setting it to silent mode can prevent the chimes from sounding.
Inspect the Cam with Humps:
The Westminster mechanical clock has a cam with humps on the front plate of the movement. These humps control when the movement stops chiming.
Run the chime by turning the hand (you can mount it with the nut, but it's not necessary). Observe the cam with the humps spinning.
Wait until it reaches the end of the smallest hump (which represents the first quarter, the shortest chime).
Stop the gear train from moving with your fingers and hold it.
Adjust the hammers from the back of the movement to match the position where the last hammer drops after the 1-2-3-4-5 hammers strike in a row, representing the end of the first quarter.
Tighten the cam so that the bar riding the cam is just after the smallest hump. This should set the chimes correctly.
Battery Replacement:
If you've recently replaced the battery, ensure that you've used fresh C batteries with high capacity.
Batteries should be changed annually to guarantee accurate timing and consistent chime sounds.
Low Battery Warning Function:
If your clock starts behaving irregularly or the pendulum stops (if equipped), it might be due to low battery. Install new batteries to resolve this issue.
Remember, these are general guidelines, and specific models may have additional considerations. If the problem persists, consider seeking professional assistance or replacing the movement if necessary. If your clock is chain-driven, you can order the 1161-053 movement from Clockworks when you're ready to swap it out.
Feb 15, 2024 • The Watches
1helpful
Why did hands come off during watch battery replacement?
If the hands of your watch have come off after replacing the battery, it could be due to a few different issues. Here are some possible causes and solutions:
  1. Improper installation: If the hands were not properly aligned when the battery was replaced, it could cause them to come off when the watch is turned face-up. Make sure that the hands are properly aligned and securely fastened to the watch movement before reassembling the watch.
  2. Loose or damaged hands: If the hands were loose or damaged before the battery replacement, they may have come off when the watch was turned face-up. Check the hands for any damage or wear and if necessary, replace them with new hands.
  3. Damaged watch movement: If the watch movement was damaged during the battery replacement process, it could cause the hands to come off when the watch is turned face-up. Have the watch movement inspected by a professional watch repair technician.
  4. Incorrect battery size: If the incorrect battery size was used to replace the old battery, it could cause the hands to come off when the watch is turned face-up. Make sure you are using the correct battery size and type for your watch.
  5. Incorrectly set the hands: During the battery replacement, if the hands were moved or set incorrectly, it could cause them to come off when the watch is turned face-up. Double check that the hands are set to the correct time and position.
Oct 31, 2022 • The Watches
1helpful
I have a sweda watch with no battery. The only identification is that the front says "Lifeline". Can you "best guess" at a compatible battery?
I can't find much on the watch. Sweda is one company, and Lifeline is another.
https://www.google.com/search?q=Sweda+Lifeline+watch
Look inside the watch and look for an engraved number near the battery socket. If nothing there, a local jeweler will have a battery that fits the space. Voltage is 1.55 volts, silver oxide are best.
Watch Battery Size Chart - 377 Watch Battery Replacement
Ad·https://www.microbattery.com/watchbatteries
For batteries at low prices, shop Microbattery for high quality watch battery replacements. Watch batteries from the top manufacturers like Murata, Renata, Energizer, and Seizeken.
‎Changing Watch Batteries · ‎364 Watch Batteries · ‎Closeout · ‎Browse All Watch Straps
Oct 14, 2022 • The Watches
1helpful
VX82 X530 Battery for Pulsar watch
The VX82 X530 battery is a replacement battery for the Pulsar watch. It is a lithium-ion battery with a capacity of 3.7V and 530mAh. It is important to note that you should only use a battery that is specifically designed for your Pulsar watch, as using the wrong type of battery can damage the watch or be potentially dangerous. Always use caution when changing a watch battery.
Yyou can try searching for "VX82 X530 replacement battery" or "Pulsar watch battery replacement" on online retailers such as Amazon, eBay, or Alibaba. You may also check with the manufacturer of your Pulsar watch or a local watch repair shop for replacement options.
1helpful
Found small spring when changing battery
This happened because the COIL SPRING was lost during the battery change. This happens quite often to DIYers, as they do not know how the watch is built and the coil spring itself is very small, so, it's easy to loose it without even noticing it. Coil spring transmits electrical signals/vibrations from watch's movement to the quartz membrane attached inside case back. Now you have to find yours or need to visit your nearest watch repair shop and ask for the new one to be fitted..
3helpful
I dont know how to make my armitron watch silent, every hour it beeps to tell me when its 1 oclock 2 3 and so on, but being in school that gets very anoying
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals. Rate me, please
Help with battery problem on Timex Ironman Data Link Wrist Watch and after installing a new battery the alarm is silent.
Help with battery problem on Timex Ironman Triathlon after installing a new battery and reset, displays the message 846010 1.0 P1and the alarm is silent.
2helpful
2answers
No sound
This solution worked for me but I also had to bend the little copper tab upward so that it made good contact with the plastic pad stuck to the inside of the back of the watch
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
