Question about Monster Cable Products Turbine Headphones
My right earpiece is suddenly quieter than my left one. Any ideas as to what may be causing it/how I can fix it?
    New Friend:
  • 85 Answers
Make sure it is plugged in all the way
Posted on Mar 08, 2011
SOURCE:
Right earphone seems somewhat quieter than the left earbud. At one point, it barely made any sound at all. Recently, it's decided to make itself louder. Still, I want to fix this. The sound quality in...
Did you tried interchanging them to the other side? If the problem changes side, try any other earphones to check that the problem is still there. If it goes, the the earphone could have a problem...try to look through the hole where the sound comes from and see if it is clogged by wax or any other thing.
Feb 02, 2018 | Monster Cable Products Turbine Headphones
Not functioning..
I would check it with a different instrument cable AND bass guitar. If you end up with the same results, it's a thermal issue with the amp and will require factory authorized repair. The amp heats up and the intermittent component starts failing....more heat, more failure. It's not an easy fix and your Behringer repair shop will have their work cut out for them with this repair.
Oct 29, 2012 | Behringer Ultrabass Bxl3000 300w 1x15"...
.my nokia suddenly turns off whenever i try to
What is the model ? But most of the problem cause due to the damage/sort of Earpiece Speaker(small speaker).I've fixed this kind of problem by changing Earpiece Speaker.Thanks for visiting fixya
Mar 05, 2012 | Nokia Cell Phones
My philips SHE9550 ear phones' right end has stopped giving sound output all of a sudden. Left one is fine. Please suggest some solution to rectify this. Is it possible first of all to resolve this or...
It depends on if the fault is on the wire due to a break or snap or if the fault is in the earphone pin. Now both of the above faults can be rectified as the wire can be joined and the pin can be replaced.
Now if the fault is within the earpiece then it must be checked if the unit is faulty- a open coil - or a wire break to the unit.
Now in all the above cases a multimeter must be used to check the continuity from the headphone pin to the earpiece. An open wire can be rectified by replacing the wire, if the earpiece unit is faulty you need to replace.
Jul 28, 2011 | Philips SHE 9550 schwarz Headphones
I have a 2005 GMC Sierra Z71 4x4 that recently started making a loud creaking noise in the front end. It is very loud and occurs instantly when turning the steering left or right, and also is noticeable...
You might want to check the ball joint. None of them have grease zerks and can dry out. They will cause a noise when turning or hitting a bump, if really bad. Hope this helps.
Aug 13, 2017 | 2005 GMC Sierra
Partial Audio Only
Have you checked your Headphones on another device to see whether its OK or not?.......sodeep
May 11, 2009 | Audio Players & Recorders
Noise right front wheel sounds like wheel bearing, 1998 Dodge 3500 Van
try steering the the car to the right and the left while driving down the road. listen for the noise to get louder or quieter as you steer the car. which ever direction you steer and it gets louder it will be the bearing on the other side. for example if you turn right and it gets louder its the left bearing because you have just shifted the vechical weight to the left side by turning right. and also in that same situation the bearing would get quieter because you have just unloaded the left bearing and put the weight to the right side.
Mar 16, 2009 | 1998 Dodge Ram 3500 2WD
Right turn signal not working, front, back or dash indicator
First check the fuse of the indicator ,it may have been blown ...
Good luck...
Nov 12, 2008 | 2001 Pontiac Bonneville
LG Rumor Internal Earpiece Toggles from Working to Not
There could be a short in the earpiece. This can be fixed at a repair center if they are stocked with the right parts. If not they can still check out the phone and see if it is eligible for an exchange.
Nov 05, 2008 | LG RUMOR Cellular Phone
Cant hear out of one side of earpiece
have you tried using differnt earphones? if the problem is still the same with different earphones then it's the ipod itself that has a problem, you'll have to get it fixed.
Feb 24, 2008 | Apple iPod nano
Monster Cable Products Turbine Headphones Logo
353 people viewed this question
Top Monster Cable Products Audio Players & Recorders Experts
 Grubhead
Grubhead
 Mikey
Mikey
ray gallant
ray gallant
Are you a Monster Cable Products Audio Player and Recorder Expert? Answer questions, earn points and help others
