This television does not have audio outputs so you wouldn't be able to connect these two devices--well the one digital audio output this television has is not compatible with any of the inputs on this Vizio. Double check please by looking for a hole/input on the Vizio that will match up with that on the Sharp television. If I am wrong and there is one then you would need the digital audio cable. I believe this television takes a coaxial digital audio cable, and the hole that would correspond to this cable on electronic devices is normally black in color.
If I am correct and there is no way to connect these two devices directly then you would connect your devices to the Sharp television for video only and connect their audio cables to the Vizio's inputs.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Vizio-VSB200-Speakers-manual/id/23494ag923/t/2/
The manual shows connections to just about anything.
Not knowing anything about YOUR receiver, you MIGHT be able to draw digital audio out somewhere. Analog audio would be available at any Tape Output. Your receiver
