Hello, I have casio exilim z110... my problem is when i take a picture with flash, there's a horizontal lines in the image, i also try to turn off the flash and it also appear! and when im using it outdoor it was so bright when you take photo's.... you can only see white.... i try to default the setting but nothing happen... can you please tell me what should i do? by the way the horizontal lines appear only in a dark place only, you can see the image but theres a line..... and it was day light when it was so bright! thank you so much for your time! (sorry for my poor english).
It seems you have to install the driver first. if you lost your camera driver just simply buy card reader, so can still download the picture to your computer.
It sounds like your sensor has problems. How old is the camera? Check the Casio site for firmware upgrades and recalls. Also search the net for others with the same problem.
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself. It's need repair camera machine shutter.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
It is the shutter (or at least it was for me) I found a simple test here: http://www.mydc.com.tw/repair/knowledge_en/casio-exilim-ex-s600-overexposure-t17.html I repaired it myself, but it took me a whole afternoon and lots of patience. The hard part is taking the camera apart, once I got to the shutter I just activated it manually so to dislodge any pieces that might have gotten jammed, then placed it back together again and it worked! :). It's really hard to take apart, it's like a puzzle sometimes, to find which screws are keeping it together. I also had a bit of hard time when it came to put the zoom back together again. But I guess it beats throwing the camera away. I'm still puzzled on how the CCD works so that an overexposure would make horizontal overexposed lines, but everything points to that. Fixed shutter, lines be gone.
It appears this problem is due a failing CCD device in many brand cameras. All the manufactures use the same source(s). I have not persued Casio as yet, but other companies are offering a recall to replace the CCD for free. I plan to use this approach with Casio. Search the web for "failing CCD in digital camera", it describes exactly what we are observing.
