Computers & Internet Logo
Joshua Larue Posted on Mar 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I tried paying my fifa 11 on pc and when I clicked play a new window opened and it said E001. What does it mean and can you tel me what to do to sort the problem. thank you
Anonymous
Level 3:
President:
  • Master 2,340 Answers
  • Posted on Mar 09, 2011
Anonymous
Master
Level 3:
President:
Answers
2340
Questions
0
Helped
716657
Points
6960
E001 error when playing FIFA 11, means that your graphic card is not supported (does not meet the games hardware requirements) in playing the game!! Majority of the onboard graphics card do not support very high graphicsPC games eg FIFA 11. ( Updating your DirectX or Graphics cards drivers will not help.)
In order to play the above PC game you have to get a better graphic card which support at least the "Shader Mode 3".
Hope it helps.
3helpful
2answers
E001 when playing fifa 11 on my pc
This error (e 001) generally occurrs when your graphic card is not supporting FIFA 11. This issue can't be removed unless you get a better graphic card.
If you want a better graphic card, you can consult THIS website.
I hope I helped you! Thank you for using FixYa!
Sir, I am having trouble with E0001 when i click on play in the fifa 2011 open window.Please help me.
This error means that you PC doesn't support Fifa 11. You will have to upgrade your computer to get this game to work.
4helpful
2answers
Fifa 11 starting time say e001 error
E001 error for FIFA 11 - Means your Graphic card is not supported in playing the game. You need to upgrade your Graphic card which support at least the "Shader Mode 3" function.
Most of the onboard graphic cards does not support this function and you get the E001 error when you play the game. Updating your DirectX or graphic card drivers is no help at all because is a hardware compatibility issue.
Hope it helps.
I am using windows xp service pack 3. fifa 11 will not open when i click on play game i get an error code E001
Hi. The bad news is that you probably do not have a graphics card that will support the game. Some of the graphics tools used to create FIFA 11 are not supported by your card (or your embedded graphics card, if that is the case). You may wish to try the Microsoft solutions suggested in the link that follows, but I don't think they will work for you.
http://support.microsoft.com/kb/310123 http://social.answers.microsoft.com/Forums/en-US/vistagaming/thread/f2978c1f-462c-41c1-be16-57a2b99086fc
Regards, John
7helpful
2answers
E001 ERROR WHILE OPENING FIFA-11
Fifa 11 Recommended Requirements:
CPU with Dual core processor (Core duo 2 or better). Intel Core2Duo @ 2.4Ghz on Windows XP / Windows Vista / Windows 7.
1 Gigabyte of RAM (2 GB required for Windows Vista / Windows 7).
DirectX® 9.0c
Compatible 3D accelerated 256 MB video card or equivalent (**must support Shader Model 3.0 or above). ATI RADEON HD 3870. NVIDIA GEFORCE 8800 GT
If your system does not support the above hardware requirements you cannot play this high graphics games & your get the E001 error.
3helpful
2answers
I cant start my fifa 2011, shows me E001
Fifa 11 Demo PC E0001 Error Issue
Fifa 11 E0001 error happened to a PC with this or a similar Specs: Pentium dual core, integrated Intel graphic card, 1GB of RAM, 128 of vid RAM, 2.0 pixel shaders.
Fifa 11 Demo PC E0001 Error Issue Fix:
1. Fifa 11 requires a shader model 3 or better card. That is error E0001 will be fixed and you can play this game again.
So if you get an error message as E0001 while playing Fifa 11 on Windows 7 or other systems, you should first set to the shader model 3 of your card.
2. This E0001 error issue may also be related to the graphic card that you are using. Check the drivers you are using for the video card. Update and reinstall it if necessary.
3. Get the latest driver pack for the same and then process out for the implementation. You can download the current new AMD catalyst 10.9 graphics card driver here. Or NVIDIA ForceWare 260.63 driver if you are using a Nvidia card.
4. Change the resolution to have a try. Some users get the E0001 error fixed for Fifa 11 by trying the 1280x1024 resolution on his computer.
Hope this solution was helpful? Please comment for more information and thank you for using fixya
3helpful
My fifa 11 no working e001 problem
1helpful
I installed FIFA 11 on my PC and when I run it it comes up with a box say 'E001'.
2answers
When i open fifa 11 in my pc then it displays the e001 error
please download fifa 11 patch and copy to game folder it will be solved bye
1helpful
2answers
I installed fifa 11 and when i try starting the game i get error e001 ... when i try to run fifa 11 i get an error message saying E001.how to fix this ...
Error e001, starting the game fifa 11
Most probably your video card does not support "Shader Mode 3 or higher".
Get a better video card.
What are your system specs? Have you updated your graphics card driver and installed the latest directx redist. In the fifa11 zip file there is a redist folder, make sure you install everything in there as well. Also, try updating your sound card driver, it may be conflicting.
Take note**
Chipsets used in models
NVIDIA GeForce 7300, 8100, 8200, 8300 und 9300,
ATI Radeon HD3200, HD4350 and
Intel/S3 do not satisfy the hardware requirements.
Hope it helps.
Grand Canyon Tech
Grand Canyon Tech
