SOURCE: hello sir i m using
hello sir i m using samsung SGH-L700 model phone, but i am unable to install mobile dictionary or any kind of games.....unsupported file format comes when i try to install that... sir plzzz help me as i bought this phone only for dictionary purpose... plzzz
SOURCE: i have use nokia 5300 express mobile i was softw...
update firmware download software updater from nokia.com
SOURCE: my micromax q5 mobile activated Aircel gprs but
opera mini not exists in my mobile q5 micromax please help me
SOURCE: SIR I HAVE NOKIA 5130C-2
Hello Sir !! Welcome to Fixya !!
You need to format/flash the memory card to get access back.There is a simple way of flashing a memory card.Put the memory card in card reader and attach it with the PC.A icon will appear in My Computer with the memory card name(usually Memory Card).then follow the these simple steps :
You are done.Place it back in your device and enjoy.
If it was helpful then please rate or a token of appreciation will be esteemed.
Flashing is the only solution, but anyway Remove Memory Card,Sim Card and reboot by inserting only the battery.Try it for 2-3 times.If the problem still persist better to contact mobile repairing shop or follow this trick.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5130 flash file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment. thanks for visiting fixya. Good luck.
