My mopped kick start was jammed the I unjamed it by jumping on it.. I need to fix it,!! He'lp!!My mopped kick start was jammed the I unjamed it by jumping on it.. I need to fix it,!! He'lp!!
You can't post conmments that contain an email address.
Sorry but I don't know anything about the electronics on the newer Twin Cam engines. I work on the carburetor equipped Evos and earlier model bikes. The first thing I'd do is to check the compression when the engine is cold. Check both cylinders and get the reading off the running cylinder to compare the not-running cylinder. If the compression is lower by about 15-20 psi, you may have a blown head gasket. This is one of the three things that you must have in order for any internal combustion engine to run. If the compression is alright, you need to check for fuel to the cylinder and ignition spark to the cylinder. The other two components necessary to run.
Is the starter turning the motor ?
If not - the starter could be stuck..
WHILE tring to start it with starter - give the actual starter a smack with a wrench..
Take the case into which the kickstart goes in, I believe that your kickstarter gear (the small gear found at the other end of the kickstarter, behind the case) has gone out of it's position, thus locking itself in position.
I think your mate is right try pushing the bike to get it going then once fired up & cleared out should be fine. Put choke on full kick fully 2x then take choke off completely, kick again.
