Your lens might have an issue caused by some sort of shock or impact. Before anything just try to gently turn the focus ring on the lens while on auto focus to see if it pops back into place. Sometimes this actually takes care of the issue. Just DON'T FORCE IT. If this doesn't solve your issue then contact a Nikon authorized service center because your lens is going to need repairs. Hope this helps!
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
That's odd that Shutterbug camera shop couldn't tell you everything you needed to know about that camera. I looked it up in a PDF manual because the new "small frame" cameras require different lenses as is the case here Autofocus with this camera is only supported by AF-S and AF-I lenses the lens is equipped with the autofocus motor other types of lenses will not autofocus.
The "kit" lens for this camera is the AF-S DX Zoom Nikkor 18-55 F3.5/5.6G VR.
Now if Shutterbug camera shop mounted an AF-S lens and the camera didn't autofocus then they are right in saying it's broke. I just find it strange they couldn't tell you that straight up. You need to install an AF-S lens and try it, again they may have put the wrong type on it and of course it won't work.
I take it that you don't have the camera manual?
If not go into Google search Type in Nikon D60 PDF manual and click search fifth one down on the first page is what you need click on it and download your "new" manual
The d60 needs Auto focus lenses(Ones with motors inside the lense) it doesn`t autofocus on other lenses. this was done to reduce the price of the camera body
I had the same issue with my Nikon d60...my 18-55mm did auto focus but
my 55-200mm only manual focused, i thought it might have been my camera
as i heard that not all lenses are compatible with my d60 but it turned
out to be the focussing motor or something that was damaged, it was
making a very funny noise when it tried to auto focus with it,like a
screeching sound..if this is the case you should get it repaired and
looked at, also check on the lens if it says it is a AF lens,if so make sure th switch on the side of the lens is switched on AF not MF. hope it helps
Your Sigma 28-300mm doesn't have a HSM-motor as far as i know. When you switch it from MF to AF, you also have to disengage the manual focusing ring by pulling it towards the camera, or pushing it away from the camera. Using the AF without unlocking the manual focusing ring may damage the AF motor.
I hope this helps,
/Chris
The lenses have a focus motor built into them.when the camera is set to auto focus, once you press the shutter button, the motor activates to set the correct focus. VR is for motion stabilization. Turn off AF on lenses and camera and see if noise stops.
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
