Technics SL-1200 Turntable Logo
Posted on Jun 14, 2017
I have 8 year old 1200's and I am having trouble with the audio volume for the left deck. For some reason when I try to use my Shure M35X Cartridges the audio is very low. When I plug in Stanton Cartridges the volume is fine. I bought new Shure cartridges and styluses and still had same problem. I made sure it was the mixer, not sure if the audio cords are faulty or the tonearm, but don't understand while one set of needles works and the other is so quiet.
5 Related Answers
Anonymous
  • 515 Answers
  • Posted on May 13, 2008
SOURCE: turntable skips during playback
The only thing I can say is to make sure you set up your cartridges correctly - click HERE FOR INSTRUCTIONS on BALANCING YOUR TONEARM properly.
If, you've balanced your tonearm, and set up your cartridges correctly, then you should not have any problems. Unless, your tonearms are damaged. But this is highly unlikely. I just think you need to balance properly.
Another note, Ortofon Concorde have a design flaw, in that they don't connect very well to the Technics tonearm. The Concorde's, have short and stubby connections on the rear, making for poor connections to the tonearm. Ortofon has addressed this issue by releasing the Ortofon OM series cartridges, and mount them to standard Technics Headshell.
If you still can't figure this out, feel free to give our techs a call 24/7 @ 1.866.668.1596 ext 1 - they can walk you through setting up, and properly testing your tonearm to see if it's damaged or not.
- DJ PRO LAB
www.DJPROLAB.com
Anonymous
  • 515 Answers
  • Posted on Jul 02, 2008
SOURCE: Technics 1210 feedback/grounding problem
Since you've already replaced your RCA cables, and tried different cartridges, the only other thing that would cause this type of issue is your tonearm. It's probably on it's way out, and will need to be replaced shortly.
You can obtain a replacement tonearm HERE, however, it's rather difficult to replace the tonearm without experience or knowledge on soldering.
We are the 1200s Experts!
DIGITAL ANALOG THERAPY
Anonymous
  • 515 Answers
  • Posted on Nov 04, 2008
SOURCE: Technics turntable distortion emisson
More than likely your RCA cables are going bad, and will need to be replaced. Not the hardest self-repair, but you will need to have some soldering skills. In addition, caution should be taken when taking apart your turntable.
Check out the following videos for self-repair assistance on these wonderful DJ turntables.
If you think it's too much for you to do yourself, get some professional assistance. Shouldn't cost too much for repair.
Hope this helps some.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
Anonymous
  • Posted on Mar 09, 2009
SOURCE: tech 1200 mk2 - really bad buzzing, VERY low sound from record
If you've had it open to replace the RCAs you're obviously alright with a screw driver. with some concentration the arm is not that hard to remove and reassemble etc.You might as well try to look at the state of the wiring in the one you already have, if you are going to consider replacing it. You have to pull out the old one anyway if you are going to replace it, and once it is out its not hard at all to unscrew the metal s part of the tonearm from the plastic part at the gimbal and then have a look at the state of the black earth wire screw connection. But before you go to all the trouble, check the state of the bearings in the gimball - if some idiot has overtightened them then you may be in some trouble because they are easily damaged that way. just have a careful wriggle to see if there is any play. beyond that, if the arm has really been abused then the silver plastic at the gimball can be cracked, but that maybe hard to see until you remove it. If all that is ok, then There is nothing apart from wiring that can be an issue here - and that is user servicable - corrosion at the earth screw connection in the arm, issues with the connections to the little circuit board where the wiring from the arm attatches to the rcas etc. You have very little to loose in trying to fix what you already have.
Anonymous
  • Posted on Apr 26, 2009
SOURCE: Dual 1009. No audio from the stylus & humming.
I can help with this issue. To keep the platter spinning in manual mode, you have to cue the tonearm up and move it so it is over the record. Then flip the lever to manual. It should stay on in this position. This is a feature and not a bug.
Regarding the audio / humming problem. The Duals had what was known as a muting circuit that engages as the turntable is cycling between rest and play. The fact that you are getting no sound may be an indication that the muting circuit is still engaged. Here are a few things you can try:
1. If the unit was recently shipped, you may need to reset the mechanical function of the turntable. You can do this by locking down the tonearm to the tonearm rest, turning on the power and then flipping the lever for a full automatic cycle. The tonearm will stay fixed to the rest, but the remainder of the mechanical system underneath will be reset to proper positioning (this is detailed in the Dual manual). Of course, this assumes that everthing was OK prior to shipping.
2. Make sure your cartridge is properly mounted with a good stylus, check your tonearm wires (both in the headshell and underneath the turntable and finally, see if you can get underneath the turntable while you run an automatic cycle to see what is going on.
Lastly, if you can't get it going, Check out Bill at www.fixmydual.com He worked on my 1019 and knows them inside and out.
Good Luck,
Jerry
I have a NAD 1600 receiver for 40 years. It always worked fine!! I just moved it 15 feet to new room and volume seems stuck on high! Knob turns but volume doesn't change. What happened??
It is funny, I was just reading an article today about New Acoustic Dimension Cassette decks saying they were top of the line and equal to Nakamichi.
The most likely reason is that the volume control needs cleaning with Electrical Switch Cleaner. You would have to remove the case and look. It is worth a quick spray.
This says it has a motorized volume control.
https://www.google.com/search?q=nad+1600+receiver+volume+on+high+volume
My thorens td-190-2 recently lost its normal output volume. I have tried three cartridges with no change. What could it be?
I assume your turntable was connected to the record deck input on your amp when you lost volume from it. Then you tried other connections marked tape or CD?
As you have tried different cartridges with no response we can assume the piece of equipment that has failed is not your record deck. Instead it is your amp. The problem you are experiencing is that the pre-amp inside your amp has failed. This pre-amp is connected only to the record deck input of the amp. The other connections don't have this pre-amp which is called a magnetic cartridge pre-amp. So connecting to them will just give you the signal only from the deck, which as you say you can hear, thus proving the cartridge is working, but will be low in volume.
If you are any good at electronic repair it will be easy to fix this pre-amp. You can find it by following the internal connections from the record deck socket back to a circuit board. The chances are this will lead to an IC that does the work. Get the IC number and search the web for it, before removing it.
Alternative you can take it to a service centre for repair if you have no experience of electronic repair.
Another option is to search the web for a magnetic cartridge pre-amp. These are sold separately as many Audio amps don't have them fitted, seeing not many people have record decks. This can be connected between the deck and one of those other inputs (don't use the record deck one). The cost of one of these might work out cheaper than repair at a service centre. The repair by yourself will of course be cheaper, unless the IC is hard to find or specialised. But a search of the web for the IC number will show how cheap it is anyway. However if the IC is expensive that will also make repair by a service centre expensive too. So you can save the expense of the repair by going for a new pre-amp.
Low volume recording on reel to reel tape deck
Problem could be in either the record or playback circuits of unit. Try playing back a tape in another machine to see what the volume is like. If also low then the issue is with the record amp circuits.
Fixing will not be cost effective, however.
Hi, I just recently accqured a DUAL 1019 and the stylus is missing. what aftermarket stylus [part number] shall i look for replacements?
The manual for the TT is available for free at http://www.vinylengine.com after you register.
If you can identify the cartridge, the stylus could be identified and found for you.
They were typically equipped with a Shure cartridges. Nearly 40+ years later they might not be available but there are lots of compatible replacement cartridges.
Just Google "shure cartridge".
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
My Technic 1200's are only playing out of one speaker at a time.
Clearly there IS a setup issue. Take serrato out of the loop for the moment and the mixer. Plug each deck (one at a time) into a hifi with a MM Phono input. Are you getting stereo? If yes, you know the decks are ok. Now reset the mixer completey. All eqs and pans including volumes to 12 o clock position and volumes to 0.
Make sure you connect deck one to a red and white of one phono input channel. Do not use 1 channel from phono and 1 from line. Use both left and right of the phono chanels.
Ok, now hook up the mixer to the amp. Keep the x-fader on channel 1 and concentrate getting a good stereo signal from this one chanel. Now do the same for the other cahnnel.
This should hae helped you to get up an running, if not narrow down the problem.
Shure sm58 just started outputting very low volume. It has been working fine with our system for years. Tried other sm58 mics on the same mic cable with same system setup and no troubles. There is still...
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
1helpful
16 year old Blaupunkt Toronto SQR 48 on/off/volume control knob ?
blaupunkt doesn't supply parts after ten years on their decks. you can try salvage yards.
Microphone feedback
Yes, it could. With age it may become less directional. It probably sounds okay but just doesn't discriminate against sounds from the rear as well. Shure will put in a new element for not too much money.
2helpful
2answers
Car Stereo Volume Goes Up and Down Erratically
prolly buy a truck and a amp from this century
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
