you can only print from an ipad using the airprint app if you have one of these printers
read more about it here
http://www.apple.com/ipad/features/airprint.html
The easiest way would be to scan the image or text to your computer, then transfer it from there to your memory card. I'm sorry but this printer model does not scan directly. Hope this helps =]
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Make sure your sheets are aligned and tucked in with the paper feed rails, otherwise, it will slightly veer off one of the sides.
Also, if you haven't replaced the paper feeder rollers, do so, one must be worn out more than the other, and this also prevents the sheets from going through straight.
