Most likely you are haveing a problem with the water valves inside of the pump. Honda does not make pumps they make the engines and if you have a honda engine its the best engine for powerwashers . S o what you need to do is look at the pump and see who made the thing . If its a simpsion or a cat pump these bolth are vary good pumps . It could be a miti m pump there ok but tend to have problems with the valveing . The kits are cheap enough for all of them about 60 or 70 dollars . So let me know how many horse power the engine is and what kind of pump you have and the gal pr munite aswell as the max pressure out put of the mechine how old is it and ware did you buy it Most of this information will be on a metal tag on the water pump or the frame of the mechine. A nd i'll tell you if its worth saveing Pier_j
