YY count the number of flashes ie 4 flashes pause 4 flashes pause. This will give you the error code and will tell what is wrong with your chair Check out my tip on Flash codes if you can't find them in your manual. Without fixing the problem that generated the flashing you won't be able to use the chair until the problem is fixed. If you want you could contact the provider that sold you the chair and have them troubleshoot the problem for you Hope this helps
