RIM BlackBerry Bold 9000 Smartphone Logo
A
Anonymous Posted on Mar 07, 2011
Hi everyone, I am having issues with my BB red indicator light is keep flashing, Was wondering way this keeps flashing and the BB is off but it keeps flashing the red indicator. Thanks for the help. but suddenly my BB of blackout but there is a red indicator light that is keep on flashing.
  • Anonymous Mar 07, 2011
    i already charge it 30 minutes but still blackout but it keeps flashing the red indicator 3x
Wale Sarumi KomputerSolution
Level 3:
  • RIM Master 6,993 Answers
  • Posted on Mar 07, 2011
RIM Master
Level 3:
Answers
6993
Questions
Helped
1700490
Points
1261
that's a sign of critical low battery. Charge the battery or your BB and problem would be solved.
Good luck.
  • Wale Sarumi KomputerSolution
    Remove the battery, fix it back, then try again. I just hope your battery hasn't developed any fault. To confirm, borrow a battery from a friend, and test it with your BB. Send me a feedback so that I can know what next to do....
I am having issue with my TV it won't turn on and I have a flashing red status light keep flashing can anyone help
Hi, if your tv is between 1-4 yrs old and havent replaced the lamp it might be time to do so.Mitsubishis uses Osram lamps to light up the screen and tend to last from 3000-4000 hrs normally 1-3 yrs.The Red light indicator usually indicates its time to replace the lamp.Heres the lamp you would need http://www.discount-merchant.com/Mitsubhishi-915P027010-915P027A10-Replacement-p/mitsubishi-915p027010-lamp.htm?1=1&CartID=0 On the same link it shows you how to replace it ,have a blessed day.
The blinking red light usually indicates there is a new message(email, text, blackberry instant messenger, etc). Verify that there are no new messages.
My new BB Bold 9700 battery suddenly drained while plugged in?!?!
keeping it plugged in shouldn't have hurt the battery. i would return it if you have a warrenty left... otherwise i would connect to bb desktop mngr and reset to factory settings.(origional settings your phone came with)
1helpful
2answers
My Red Blackberry Curve 8310's Indicator light keeps flashing
you would have to reload the OS back to the device from the blackberry desktop manager software (application loader) but basically your phone is fried.
Blackberry bold suddenly shut down
Lots of battery issues with the Bold. Try taking the battery out, keeping it out and connecting to PC with USB. Do any lights come on? Red light should appear. Put battery in while connected to USB.
Another fix that I found for a friend-leave the battery out of the unit for a day-put it in and plug in power cord or USB. It worked.
3helpful
Fridge freezer lights flashing
the flashing red light indicates a cooling problem,you should call honest local appliance repair shop(not sears they rob you blind)one other thing to try is to unplug for 5 minutes then plug back in and see if it reset sets itself,could be just a board reset issue,let me know-mike
Jun 10, 2008 • Freezers
374helpful
23answers
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
