Honeywell HHT-145 Air Purifier Logo
Posted on Mar 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gentlemen: The LCD display on top of the purifier indicated that the filters were dirty. We removed the 2 filters, vacuumed both sides and reinserted them. We are still getting an indication that the filters are dirty. What should we do? Thank you. JR
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Mar 07, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2104702
Points
14643
According to what I found, if the filter is not reinstalled just right, it won't trigger the filter being back inplace switch.Also, try unplugging the unit for 30 minutes and then plug it back in. That may reset the switch. If tall else fails, call Honeywell Customer Service at 877- 841-2840.
Hope this helps to solve the problem, JR.
How do I remove the filter
Lancaster air purifiers can have different models and designs, so the exact location and method for removing the filter may vary. However, I can provide you with some general guidance that should help you locate and remove the filter in most air purifiers.
1. Check the user manual: The first step is to consult the user manual that came with the air purifier. It typically contains specific instructions on how to access and replace the filter. If you don't have the manual, you can often find it online on the manufacturer's website.
2. Look for a filter compartment: Most air purifiers have a designated compartment or access panel where the filter is located. It may be on the back, side, or front of the unit. Examine the air purifier and look for any labeled panels or compartments that indicate the filter's location.
3. Remove the filter cover: Once you've located the filter compartment, you'll need to remove the cover or panel to access the filter. The cover may be secured with screws, clips, or latches. Use a screwdriver or your hands to undo the fasteners and carefully remove the cover.
4. Take out the filter: After removing the cover, you should see the filter inside. Depending on the model, the filter may be a single unit or consist of multiple layers. Take note of how the filter is positioned before removing it to ensure you can correctly replace it later.
5. Follow any additional instructions: Some air purifiers have specific instructions for removing the filter, such as pressing a release button or sliding it out from a designated slot. Refer to the user manual or any labels on the unit for any additional guidance.
6. Clean or replace the filter: Once the filter is removed, you can determine whether it needs cleaning or replacement. If it's a reusable filter, check the manufacturer's instructions on how to clean it properly. For disposable filters, it's generally recommended to replace them according to the manufacturer's guidelines.
Remember to consult the specific user manual for your Lancaster air purifier model to get accurate instructions tailored to your device.
tip
How to Reset Your Air Purifier Filter Light
<span style="font-weight: bold;">Airgle Air Purifier:</span><br /> <ol> <li>Turn off and unplug the unit </li> <li>Press the light button to the "on" position </li> <li>Plug in the unit, and then release the button after the Filter-check starts</li> <li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li> <li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li> <li>This time, the system should report an accurate result. </li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br /> <ol> <li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li> <li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br /> <ol> <li>Units which have an indicator light must be reset once the HEPA filter has been replaced. Reset indicator by inserting a small object (such as a pin or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br /> <ol> <li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br /> <ol> <li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br /> <ol> <li>Change the filter and/or pre-filter.</li> <li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li> <li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br /> <ol> <li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li> <li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li> <li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li> <li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li> <li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br /> <ol> <li>Press the FUNCTION and OFF TIMER buttons at the same time for five seconds. The CHANGE FILTER INDICATOR will flash five times and turn off </li></ol>
on Jun 17, 2011 • Air Purifiers
I have an Afloia Air Purifier. The red light keeps blinking?
Question edited for clarity, dreadful spelling and typos. :>D
Question moved from Televisions to Air Purifiers.
Your air filter is dirty and needs cleaning.
Afloia Air Purifier Blinking Red - Repair, Care and ...
https://plentifulair.com > afloia-air-purifier-blinking-red...
A flashing red light in all Afloia air purifiers indicates that the air filter needs to be replaced. Typically, in these air purifiers, the red light turns on ...
Why is My Afloia Air Purifier... · ‎How to Replace the Air Filter in...
11helpful
I just replaced my filter for the winix 5300 model and the replace filter indicator does not seem to turn off. Are there any solutions or procedures as to how i should go about this matter?
Remove the front cover and locate the FILTER RESET button below the DUST SENSOR level display indicator lights. Press and hold this button for 3 seconds until the unit beeps and the REPLACE FILTER indicator light goes out.
2helpful
Blueaire 501 dust caked up on wires and fan,how do you take it apart to clean it?
Hi, I have had the same problem and have figured out how to open it.
To open your blueair air purifier, follow the steps below;
1. Get a phillips head screwdriver,
2. Open the unit and remove the air filters.
3. Use the phillips head screwdriver to remove the screws that you can see.
4. After taking out the screws, remove the "galvanizedSwedish steel housing"
(cream coloured sides) of the purifier by lifting it upwards (i.e. from bottom to top of unit).
4. You will now have access to the interior of the purifier.
5. You can now take out the fan and clean it, or what ever part you are trying to clean. I used a Dyson HEPA vacuum cleaner.
6. To reassemble, reverse the instructions above to reassemble the purifier.
The manual does not say what the dials are for on the top right side of the unit under filter. What is the purpose of this 2 digit dial?
Kenmore 85244 Air Purifier Air Purifier The manual does not say what the... Answer Failed: retry The manual does not say what the dials are for on the top right side of the unit under filter. What... (More) (More) The manual does not say what the dials are for on the top right side of the unit under filter. What is the purpose of this 2 digit dial?
10helpful
I do not know how to clean it. It is called Fresh
The Fresh Air has a reminder on the LCD to Perform Cleaning. This reminder will display if the purifier runs for 30 days. When this reminder is displayed perform the following steps to clean your purifier.
1. Cleaning the Case:
Wipe the unit with a soft cloth dampened with water. Do not use chemicals or solvents. Vacuum the front and rear grills to remove any lint buildup.
2. To clean the lint screen, RCI cell and purification plate:
3. To remove the back cover:
Remove the plug from the back of the unit. Unscrew the screw above the plug socket on the back cover. To remove the back cover, press the back sides of the back cover to unlatch and tilt the bottom of the back cover to remove.
4. To remove the rear lint screen:
Remove the two thumbscrews holding the top of the lint screen. Remove the lint screen by pulling back the top of the screen, then lift it up and out.
5. Removing the RCI cell:
Remove the RCI cell connector by pressing the connector locking tabs. Pull the connector straight out to unplug.
Remove the RCI cell by removing the two thumbscrews. Slide the RCI cell down and out of the unit.
6. Cleaning the RCI Cell:
Remove the RCI cell and carefully vacuum accumulated lint. Do not wash the RCI cell. Damage from water may result.
7. Rear lint screen cleaning:
You have two options
  1. When visibly dirty, simply remove the rear lint screen from the unit and with a duster attachment on a vacuum, remove the heavy particulate.
  2. In addition to step 1, the filter can be washed with hot water (do not use soap). Allow to dry prior to reinstalling. Replace if damaged.
8. Cleaning the Purifier Plate:
Remove the plate from the card cage by grasping the middle edge nearest to you, and slowly pull it straight out. Clean with mixture of one part water and one part ammonia. Place plate and ammonia mixture in a dish and allow it to soak for no more than 10 minutes. Remove plate and scrub with a toothbrush. Rinse thoroughly and air dry for 24 hours or use a blow dryer to dry thoroughly.
After all parts have been cleaned and are thoroughly dry, reinstall components in reverse order. Turn the purifier on, and on the key pad, press the reminder Reset button to clear the Perform Cleaning message.
If this has been helpful, please rate this solution. Thanks
4helpful
3answers
Users Manual for Kenmore HEPA Air Cleaner Model No 85244
I have an kenmore air purifier and cannot locate where to find a replacement filter or manual for it? Can you help. It is Model # D42M32957
2helpful
Red light won't stay off
I do apologize for the inconvenience, the best way that i can tell you to fix the light is that there is a tiny pin hole on top of the unit. that's a reset button. you need a small needle or something that will fit in there. hold it down for about 3 seconds. your unit should reset. the light sometimes comes on with new filters cause it hasn't recognized that they are new yet. if that reset doens't work please let me know
Top Honeywell Air Purifiers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
