Fuji FinePix F700 Digital Camera Logo
Anonymous Posted on Mar 07, 2011
I've lost the power supply (charging capibility) for my Fugi F700. Can I buy another?
Anonymous
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Mar 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
3974
Points
74
You should be able to goto any camera store, and they should have it as accessories. If not you can always go on www.ebay.com and search for finepix f700 adapter.
  • Anonymous Mar 07, 2011
    Also another option is to get a battery charger for that model as well.
Laptop runs on battery and charges ok,but wont run just on the charger-hp f700
Charger go true a lot of power voltage regulators and in the end is not powerful inought to power loptop without battery, same capasity neaded to help maintain stable curent.
Compaq f700 won't power up
4 possibilities.
1 The Compaq f700 power supply is duff. How do you know it is actually working? Have you been able to test it on another system?
2 The charging circuits in the laptop have failed. Only a workshop can test this.
3 The Battery is dead. How do you know it is good if the system is not working?
4 There is a mechanical connection problem. Damaged lead/plug/socket etc. Examine and swap out to check.
Note that the system would not work if 1, 2 and 4 were the problem. (Since the system should still work of AC even without a battery).So a battery problem is the lowest probability.
1helpful
3answers
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
I have a Fugi Finepix JX 250 - I've lost my usb cable and want to download pictures onto my Apple computer. What cable do I need?
Having gone over a month without a reply to my query, I assume my suggestion to use a card reader eliminated the need for a cable.
When I try to power on my compaq pesario f700 laptop the light just flashes once and nothing happens I assume its the power supply of the laptop can I replace this myself I am very Tech savy and have...
Remove your battery and try with external power supply again if it boots up all good and proper then after booting to SOE refitt the battery and let it charge - if it doesn't boot or power on look to see if the blue LED it on around your power input point. If there is no illumination around the power input port try another 65w power supply input - your power pack may be dead. Cheap fix - if it still does the same powers on then off - you have reason to go out and buy a new laptop - would be cheaper than replacing the M/board
trust me.
My compaq presario is not switching on.
Could be a number of things, related to the power supply. However if there are any lights on then it is likely to be a motherboard problem. Contact a local PC repair shop. I had a simiar problem and it was the on board video card. They should not charge to diagnose the problem. Mine cost £80 to fix at PCZone, Birchwood.
1helpful
Cant turn On my Compact presario f700
Assuming you have checked the the power strip or outlet by testing it with another electrical appliance to see if it is in operation, you can test
the power supply to the unit with a tester or oscilloscope. If it still does not work then check the cable that plugs directly into the unit and replace it if necessary. You can also open the unit to check if the cable is attached properly to the motherboard.
Presario f700 no fan/lights = nothing at all. The charger works
try to jump green and any black wire from the power supply...if the fan dont work..power supply is damage..need to change..
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
