Dishwashers Logo
Dominga Wells Posted on Mar 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My newer model dishwasher has locked up. Clean LED light continues to blink. Any ideas? This happened once before and a sequence was given to me that I no longer had :(
Anonymous
Level 3:
  • Dishwashers Master 1,902 Answers
  • Posted on Mar 07, 2011
Anonymous
Dishwashers Master
Level 3:
Answers
1902
Questions
0
Helped
533817
Points
5669
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
6helpful
2answers
How do you reset a KitchenAid dishwasher model: KUDE70FXSS4?
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
5helpful
3answers
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
2answers
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
8helpful
Clean light blinks 7 times continuously
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. Let it go through the diagnostic to test the function of the element.(1-2 minutes). When it finishes, open the door and touch the element to see if it is hot (be careful, it can get pretty hot so wet your fingers to avoid burns).
Once the diagnostic has cleared, you should be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
1helpful
Kitchenaid dishwasher woudl not work MOD KUDPO1FLWH6
is it on steady??? or blinking??? if on steady try pressing nad holding the button with the "lock" symbol on/or above it, thinknits the heat button, for 3 secs it will "unlock" the controls, if blinkin then its a diff issue, may be a bad door switch not recognizing hte door being closed therefore wont start,
Dec 02, 2008 • Dishwashers
Maytag (MDB-1) Dishwasher Controls blinking
hi alex,
could you please provide me with the complet model # of your dishwasher?
thanks,
carmen
Sep 24, 2008 • Dishwashers
10helpful
2answers
Cancel Light Flashing on Kitchen Aid Dishwasher
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
11helpful
2answers
Clean ligh is blinking
youll need to remove the bottom acess panel of d/w there should be an extensive trouble shooting guide tapedto back of panel in a sleeve, lotsa good stuff in there. depending on buttons its going to repuire pushing a sequence. "
sani-rinse---heated dry--sani rinse--heated dry.
it will enter a diag mode "all lights will light up" wait a few secs and then cancel cycle .. if happens a again or with frequency, then call a servicer, you have a problem, first time chaulk up to a fluke
Top Dishwashers Experts
Mike Cairns
Mike Cairns
john h
