Belkin (F5D7230-4) Router (587009) Logo
Posted on Mar 07, 2011
When i connected my belkin n150 it wont connect to the internet the modem light flashes amber ,It says connected on my laptop but the modem light wont stay green
  • 2 more comments
  • Tony Mar 07, 2011
    is this DSL or Cable?
  • jyedee01 Mar 07, 2011
    its cable
  • Tony Mar 07, 2011
    Are you able to login to your belkin device?
    I believe the address on firefox or IE would be 192.168.2.1
    login and check your connection type Internet type and see if your set to DHCP.
  • jyedee01 Mar 08, 2011
    solved it ..I went to command prompt and typed in ipconfig/renew and problem solved thank's
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Mar 08, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
7153
Points
37
Your Router Should Be Configured for your Internet Service Provider. To do that you have to contact your Belkin technical support & they will give you a hand. Or Please update some Details about your Internet connection who is your Internet Service Provider. What type of Internet Connection are you using is it DSL or Cable. And i will walk through the Steps For you... :)
Amber light flashing on belkin 150 router
Disconnect the ISP modem power and network / cable. Do the same with the router. Wait a few minutes and reconnect starting with modem.
I have a new belkin n150 when i conect to the modem, there is a amber flash light for the modem on the router, when i conect the computer directly i have conection, i have folowed all the instructions but...
This indicates that router can't detect cable modem or this is unresponsive, probably your modem is logically tied with your PC (MAC address associated), that's why when you connect them directly work fine, if this is the case, you'll have to clone the MAC address of your PC into your router, this should be at Setup Menu, Manage MAC addresses option.
1helpful
I have Belkin N150 Rouer. My internet is Time warner. It has no connection between the modern and Belkin router. How can I set up Belkin N150 Router to solve this problem?
f the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
NOTE : IF YOUR INTERNET SERVICE PROVIDER IS CABLE FOLLOW THE BELOW STEPS
3.Under Internet WAN , SELECT the connection type as Dynamic.->NEXT
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 60 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
FOR PPPOE OR DSL CONNECTIONS
1.Under Internet WAN , SELECT the connection type as PPPOE ->NEXT
2.ENTER THE USERNAME & PASSWORD PROVIDED BY YOUR IN INTERNET SERVICE PROVIDER
3.CLICK ON APPLY CHANGES
For any advanced help, revert asap!
Thanks and regards,
MILAN
2helpful
Unable to configure my wireless belkin N150
As i understand you have a router provided by your ISP: MTNL, you need to configure the Belkin router in Dynamic mode and not in PPPoE. Then restart the devices by unplugging the power from MTNL router and Belkin. Wait for 20 secs, then power up MTNL router 1st, wait for all lights to get steady and finally power up the Belkin wireless router. Then you will find the modem and internet light lit up properly.
For any further clarifications, revert!
Thanks and regards,
Arvind
3helpful
2answers
Flashing amber modem light on belking n wireless router
Actually there is no problem with the Modem
First Get the following Information from your ISP
1 ) The Connection Type
2 ) If it is PPPoE then Get the user name and Password
Step 1 : Connect Modem - Router - Computer (Wired)
Step 2 : Open RSP By typing 192.168.2.1 on the Address Bar of the internet explorer
Step 3 : On the Left Side Under Internet WAN Click
Connection type
Step 4 : Leave the Password Blank and click Submit
Step 5 : Select the connection type as given by the ISP
Step 6 : Click Next
Step 7 : Type Username And Password for PPPoE ,Click Apply Changes
Step 8 : There is no need to type Any Host Name for dynamic Click Apply Changes
Step 9 : If it is A Cable connection then
Step 10 : On the left side Under Internet WAN Click MAC Address
Step 11 : Click Clone
Step 12 : Click Apply Changes
Step 13 : Restart the Router
Step 14 : Check the Internet Status
1helpful
1helpful
Trouble setting up my belkin N150
Do you have a user name and password to connect to the internet?
If you have that then you will need to set the router to PPPOE connection.
If not , then you will need to set the router to DHCP mode.
First make sure that your computer will be able to go online through the modem. It is very simple and you don't need the CD.
You can set up the router like the DSL connection.
Click Here for more info on how to set up the router.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
