LG 42LC2D 42 in. LCD HDTV Logo
Posted on Mar 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 42 lcd LG tv has sound but no picture...i tried unplugging everything to reset, but did not work.....what can i do?
Anonymous
Level 3:
  • Master 325 Answers
  • Posted on Mar 07, 2011
Anonymous
Master
Level 3:
Answers
325
Questions
0
Helped
67347
Points
1013
I would try to look on the power supply first for popped capacitors that supply the 24v rail for the backlight inverter.
Having sound is a positive when it comes to repair. This means that only your screen is not lighting.
If you repair the 24v line and check the 5v feed also going to the ps_on (on) the backlight inverter and you still have no picture...you will need a new inverter.
Hope this helps! Please rate if this did :)
2 Related Answers
Anonymous
  • 6 Answers
  • Posted on Apr 29, 2009
SOURCE: LG 42 LCD no sound or picture
This is probably bad capacitors on the power supply board. My LG 42LB1DR has a known problem with this and I replaced the four bac capacitors myself and saved 5-6 hundered dollars that I was also told that it would cost to fix. I fixed for under 10 dollars and about 20 minutes. LG knows about it but they dont really want to admit it. My TV was only 26 months old when this happened. The four capacitors are made by Samxon and are 2200uf @ 10v. They are junk so even if you have the entire board replaced for say $200 its just going to happen again. They need to be replaced with a different brand.
Anonymous
  • 100 Answers
  • Posted on Feb 25, 2011
SOURCE: 42" LG lcd tv has sound but no picture
Hello, If there is a complete darkness on the screen, it is likely that the problem is on the card that responsible for providing backlight to the screen. Known as invertor. Sometimes the causes are: 1 loose contacts across the card. 2 the main ic that is number begins with OZ .3 More rarely missing of the 24V voltage that provided to the invertor, in this case you should check the power supply. I hope it was helpful!
Let me know if more help is needed.
3helpful
How do you do a master reset on a 42 inch LG plasma TV?
unplug the tv and let stay unplugged for at least 24 hrs then try it if that dont work then it sounds like a power board issue
LG 42LG50 42 in. HDTV LCD TV just hooked digital box to tv , and signal is lost after a while. picture shows audio lost, please help.
Reset ur tv by unplug,replug it an hour later.Do the same with the digital box.Go to ur tv menu.Go to AUDIO setting,go down to reset,ur audio should return to factory setting,should have sound return.
I have perfect picture but no sound on my LG 42'' flat screen TV
Unplug,replug the tv about an hour later.Reset the audio setting back to factory setting.Ushould get audio back.If u not getting sound back than ur main Tuner Signal board have problem.
2answers
LG LCD TV/DVD - I have full picture and sound with
is a mute function enable or a defective control board. Needs to be checked. send to repair store.
1helpful
3answers
When using an HDMI cable there is no sound
Unplug,replug the tv about an hour reset the audio back to factory setting.Should work if ur main tuner signal board is good.
1helpful
I loose my picture but i still get sound
Just try to reset so picture will come again, some LCD TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the LCD TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the LCD TV power button for five seconds.
4. Plug the LCD TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the LCD TV is responding again.
6. Turn off the LCD TV and reconnect the devices.
7. Turn on the LCD TV.
Hope it may help you;
Regards;
VOTIT
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
93helpful
3answers
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
