Diagrams begin on page 47
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
The F3 error code indicates that the EOC (Electronic Oven Control board) senses a problem with the oven temperature sensor. You could have a defective sensor, a failed EOC or a bad wiring connection between these 2 components.
Normally, a technician is needed to diagnose and repair this type of failure. The technician would unplug the range and access the EOC in the console. He would pull the 15-pin plug from the EOC and measure the resistance between pins 12 and 13 of the plug. This would check the temperature sensor and connecting wiring. The tech should measure about 11000 ohms at room temperature (75 degrees Fahrenheit).
If this reading is good, the EOC would be the failed component and would need to be replaced.
If the resistance reading of the sensor circuit is bad, the reading would be taken directly from the leads on the temperature sensor. If the resistance reading taken directly off the sensor is bad, then the temperature sensor has failed and would need to be replaced. Otherwise, the wire harness is the failed component.
If you have a volt/ohm meter and the technical expertise to safely access and test internal components of your range as described above, you may be able to diagnose and repair the range yourself.
