SOURCE: clock and oven inoperative on elan rangemaster 90
Your electronic oven control (clock) has failed. This being a new appliance, it will be covered under warranty. Call the dealer and ask for the manufacturers warranty/customer service phone number or ask if the dealer provides warranty service. You will need to provide them with the Model and Serial number to obtain service, so have this ready when you call. After service is complete, please connect your oven to a quality surge suppression/arrestor device. We recommend these... http://catalog.belkin.com/IWCatProductPage.process?Product_Id=124911 , they can be found here... http://www.belkin.com/wheretobuy/show.aspx?pid=&targ=19&ttr=3e86a31d-23dd-4b8d-acbf-2adf1ce9ecc0&cid=1
SOURCE: rangemaster 110 main oven does not work
That looks like a problem with the control panel assembly.
Try first unplugging power cord for ten minutes, then plug back.
Press the selector wheel for 5 seconds and see if this reset it.
If that does not work , then you need to replace the control assembly. YYou find diagrams and replacement parts by entering the model number here.
SOURCE: rangemaster classic 90
Regardless of the clock running, if the timer is not set to zero and off, the oven will not function. See my instructions on using the timer (http://www.fixya.com/support/t1416237-timer_instructions_rangemaster_toledo) I hope that this is your problem and it will show you how to get the oven going again.
SOURCE: rangemaster toledo 110
Hold down two left hand buttons together for a long time. that should do it.
SOURCE: What do I look for? Rangemaster Kitchener 110
Problem solved, took the back off the inside of oven and the element had a huge burn hole in it. Brought a new element from the local spares shop £17+vat. Easy to fit and it works better than ever.
