You can connect it with USB connection to your computer. It should be plug and play, but some drivers might be required.
You can connect it also via MIDI interface:
- you will need sound-card with MIDI input connector, or you can use special MIDI device like M-Audio UNO.
You can connect it with a USB cable, but first you should go here
http://usa.yamaha.com/products/musical-instruments/keyboards/arranger_workstations/psr-3000/?mode=model
select the Suppot tab
select the USB-MIDI driver you want
on the next page select USB-MIDI Driver Installation Guide
and follow the instructions there.
Hope this was helpful
SOURCE: need video demo of Psr 3000
Click here and then once you are there watch the first two videos and then check out the others those are about the best at the current moment I will try to dig up some more for you.
