Yes and NO your tv is a LED. To be exact it is a LED Backlight LCD TV. An LED-backlight LCD television is an LCD TV that uses LED backlighting instead of the CCFLs used in traditional LCD televisions. It is not a true LED display but is called "LED TV" by some manufacturers.[1] The use of LED backlighting has a dramatic impact, resulting in a thinner panel, less power consumption and heat dissipation, and a brighter display with better contrast levels. You can go to http://www.regza-asia.com/pdf/LEDTV/XL700/47XL700SPEC.pdf and look at the complete specs for your tv
I have purchased REGZA 42XL700E 1 month back. At screen corners it showing decozing (white dots). What will be the reason? Is this TV is magnetic field proof?
Yes, it is led. led tvs are lcd, led just means the light is newer technology, but the screen itself is still lcd.
Your TV has a light sensor that changes the brightness of the TV based on room brightness.
It's called an "Intelligent Sensor"
You can turn this off in your "Picture" settings.
Congrats on such a nice TV purchase.
If this was helpful, please rank me a 4.
