SOURCE: PHONE WILL NOT RING
Hi it sounds like your problem is that the call diverts are set to divert all calls what you need to do is goto settings then goto call settings then look for call divert settings what you need to do is cancel all diverts and then go through them one by one and just
activate divert if off (activating this one goes to ans phn if phn off
activate divert if busy ( goes to ans phn if your on phone call)
activate divert if out of reach (goes to ans phn if no signal)
After doing these settings then your phone should ring when someone calls you.
Before you activate any divert setting select cancel all diverts then get someone to ring you and make sure phone rings the screen will now display whos callind and the phone should also ring.
Let me know if you need further assistance ok let me know how you get on
SOURCE: home phone giving a high pitched dial tone .
This normally happens when the exchange junction box nearby has some problem... do call the line man to clear the problem
SOURCE: chocolate LG -- I'm calling but nothing happens, I can't hear a ring or anyone answwering the call
LG Chocolate is the worst phone EVER! i've already self-fixed two problems, and now a new problem that i cannot make phone calls / receive them (they do actually go through but i can't hear anything). someone please tell me how to fix this....
SOURCE: pap2 phone adapter
did u have balace in your pep2 line if u not have balance then its will be happen or ur account has been deactived
SOURCE: no dialtone
If you use Dsl as a internet provider make sure you have the filters on each phone. If you use cablevision and have a wireless connection make sure you chage the phone to a 5.2ghz because you might have the wireless router with the same ghz causing a coflict. This will also create loss. of internet connections then you use the phone
