This is a movie u burn with a computer duplication software correct one to one exact coppy?Yes,go to the movie main menu should have languages like French,Spanish,English.Should able used ur DVD remote controller to chose and pick the language u wanted.
Possibly you just need a new power supply/battery charger.
There is nothing "magic" about the original power supply.
Take the player into an electronics supply shop. They should be able to look at it and match
Voltage In
Voltage Out
Power requirement (milliWatts or Watts)
Connector Type
Polarity (center of plug positive or negative)
Sometimes when you unplug the set ffrom the wall power or a while 1-2 minutes, and then plug it back in the problem will resolve itself. The DVD may eject. If it does, check it for damage, warping or dirt. If this does not fix it- you probably should take it to a repair center.
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
