Cobra 148 GTL 120-Channels Base CB Radio Logo
Anonymous Posted on Mar 07, 2011
Not transmitting good at all on ssb the power come back
Iron
Level 3:
  • Master 3,018 Answers
  • Posted on Mar 07, 2011
Iron
Master
Level 3:
Answers
3018
Questions
Helped
1670438
Points
10301
Did you have your radio "peaked?" If you turn a Cobra Sideband radio up to much it may be great for the AM side but can crush the Sideband side. Make sure it is on frequency too. Use a frequency counter to check. Make sure your SWR is 1-1:5 and no higher than two. You may have to take it to a tech and have them but it on a scope.
Yaesu 857D very poor audio out on SSB.
Dbl check your swr in am mode.. Ch your ssb power and mic gain default is 50 on both on hf .. If you use the mh-59 you will need to reduce the mic gain to 35 and it needs to be set for remote mic in the menu. Also the ssb needs to be set 2.5k wide with the ssb carrier zeroed both tx and rx
Radio power`s on but no transmit or receive on ssb however it will transmit with full power on fm
If your receiver was operating previously but now the SSB option is not working, very likely the sideband detector has failed. I'm not directly familiar with your Yaesu unit but, in most Yaesu transceivers, the SSB chip and control circuit (including diodes) is identified in print on the main board.
Yaesu ft-990 no receive or transmit
Lynn, SSB (Single SideBand) only applies to AM (Amplitude Modulation) transmission. There is no way to broadcast SSB in FM (Frequency Modulation) mode.
Galaxy melaka ssb receives but wont transmit whats the fix
look for other fingers that have been in the radio. then back track from there. It could be a switching diode thats burnt.
Receive is ok, but when I transmit on SSB the Freq. jumps 10KC. What adjustments can I do to get the transmit back on Freq. without effecting the Receive?
go to you tube and type in your radio make and model and watch the review on that radio there is a freq adjustment pod for ssb adjustment. they might tell you if not take it to a radio tech and he should be able to alighn it. there is more than one pod for ssb transmitt and receive.
Powers up ,receives,but no transmit
This is never a good sign. This is usually a sign of a bad final.
If the radio doesn't transmit in SSB or AM, then it either means, Both finals are bad, (which is rare) or there is another problem causing the problem.
If it transmits in SSB, but not AM, then the AM final is blown and needs to be replaced. Its a job for a tech.
If both SSB and Am are not working it needs troubleshooting by a tech.
If you feel ambitious, you can pull the bottem cover off being careful of the speaker wires and make sure the TX section is connected.
Inside the radio, there will be one wire with a plug that is hooked to a pin near the center of the radio. And an empty pin. The empty pin is the test pin, ignore it. Make sure the plug is on the pin all the way, and not loose. If its on good, then it needs further troubleshooting.
Other things you can check:
Make sure the mic works.
Make sure the mic gain is up.
5helpful
2answers
How to adjust frequency on transmit??? Galaxy
hELLO THERE
hERE IS SOME MODIFICATIONS FOR THIS RADIO
Galaxy Mods DX 2527 - VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...Hi Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VC 1....10.240, VC 2....10.240. DX 2517- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5....FM Deviation, VR 6....SSB Carrier Balance, VR 7....TX Offset, VR 8....CW Beep Level, VR 9....RF Meter, VR10...Final Bias, VR11...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM/FM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM/FM Low Power, VR601..13.8 Volt Power Supply. DX 22B- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR11...Driver Bias, VR12...SSB ALC, VR13...High Power, VR14...AMC, VR15...AM Low Power, VR16...SSB Low Power, VR21...TX Offset, VC 1....10.240, VC 2....10.240. DX 11B- VR 1....AM/FM S-Meter, VR 2....SSB/CW S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...CW Tone Level, VR20...Final Bias, VR21...TX Offset, VR601..13.8 Volt Power Supply, VR803..AM/FM Low Power. DX 77HML, DX 88HL, and DX 99V- VR 1....AM/FM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 7....SSB Carrier Balance, VR 8....RF Meter, VR10...Final Bias, VR11...Driver Bias, VR12...SSB ALC, VR13...AM/FM High Power, VR14...AM Modulation, VR16...AM/FM Low Power, VR20...Final Bias, VR21...TX Offset.
Unmarked VR in R189..AM/FM Medium Power for DX 77HML only. DX 33HML, DX 44V, DX 55V, DX 66V, and DX 73V- VR 1....AM/FM S-Meter, VR 4....AM/FM Squelch Range, VR 5.....FM Deviation, VR 8....RF Meter, VR12...Low Power AM Modulation, VR13...AM/FM High Power, VR14...High Power AM Modulation, VR16...AM/FM Low Power.
Unmarked VR in R188..AM/FM Medium Power (DX 33HML only)
Unmarked VR in C139..Med Power AM modulation (DX 33HML only) DX 949,DX 959- VR 1....AM S-Meter, VR 2....SSB S-Meter, VR 3....SSB Squelch Range, VR 4....AM Squelch Range, VR 6.....SSB Carrier Balance, VR 7....TX Offset, VR 9....RF Meter, VR10...Final Bias, VR12...Driver Bias, VR13...SSB ALC, VR14...AM High Power, VR15...AM Modulation Meter, VR16...AM Modulation, VR17...SSB Power, VR18...AM Low Power, VC1....10.240. DX 2517 and DX 2527-
Symptom:Buzzing or motorboating sound in either the transmit or receive.
Problem: TR602 is oscillating
Cure: Replace C602 with a .01uF cap {Cap is located in the power supply board}.
RG 66,99,DX2517 Replace Q54 2SB754 60watt 7A with a higher power 2SB817 100 Watt 12A. Derating of this component will cool operation, provide better voltage stability,decrease wobble, allow voltage increase to 14.5 volts comfortably. (replace 10 volt caps in this section of the radio to a minimum of 16 volts before increasing supply voltage to this level)and provide faster swing rise time, Replace Q37 2SA473 to a 2SA1012-0 or ECG153 this will improve the clarity and volume of the modulation and it will also run a lot cooler.
2answers
Just want to know if i should use my ll203 amp in am or ssb mode when running with a cobra CB radio?
What radio?? Does it have single side band(SSB)? If not, then don't use SSB.
AM - amplitude modulation
SSB - single side band.
If you have SSB, there would be a switch on it to transmit in SSB. If not, it is AM only.
Second, Has this radio been worked on to be able to run on an amp? If not, you will blow the amp.
A CB radio transmits dead keys with 4 watts of power, and transmits with 4 watts of audio.
a 4 watt dead key is too much for a linear amp. You will smoke the transistors. Also, 4 watts of audio is not enough to drive it properly. You won't get full power.
The dead key needs to be around 2 to 2 -1/2 watts,or what ever makes the linear dead key half its peak wattage., and the modulation (audio) turned up all the way.
It doesn't sound like you know too much about CB radio's. Not a big deal, you can learn. For right now you may want to take it to a cb shop and tell them you want a peak and tune, and set up to run a linear.
You can find CB shops usually at truck stops. Some area's they are other places. Check the internet for local shops.
2answers
No AM carrier or modulation. SSB transmits good
what cb is it ? it sounds like your am section is not getting powered up when you switch from ssb to am. If i know the model i may have a diagram of it here and suggest a place to start
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
