The available drivers for the CCD-TRV608 (the CCD-CRV608 isn't listed at Sony are here: http://esupport.sony.com/US/perl/swu-list.pl?mdl=CCDTRV608&LOC=3 . These are for Vista and older versions of Windows; however I can't tell if the 64-bit version is supported.
With Windows 7, try the Vista driver.in the compatibility mode. Right click on the installer and choose Properties. Set the program to always run as compatible with the older version of Windows. Then right click again on the installer and choose Run As Administrator. This may or may not work.
If that doesn't work, you should try a computer with a version of Windows that is compatible with the drivers from Sony. This will always work. You can use a physical computer (either a second computer or a dual boot computer) or a virtual computer. In the case of Win7 Pro or Ultimate, you can do this for free. Download and install Microsoft's Virtual PC and the XP mode. Install the camera drivers in the XP computer as if it were the only machine. (You will need to save files to optical or other removable media to share them with the Win7 computer.) For all other options, you will need a valid copy of an older version of Windows. (Other virtual computer programs are Parallels and VMWare.)
I hope this helps.
