Fault P0700 just means the PCM (Powertrain control module) has had a command from the TCM (Transmission control module) to trun on the Check engine light to alert you that a fault has occurred in the Transmission, the real problem code is stored in the TCM not the PCM, you must have the dealer test the TCM for the fault code to find out what is casing the TCM fault
Trouble Code Conditions:
Engine started; vehicle driven in a forward gear, and the PCM detected that the O/D Pressure Switch circuit indicated open or closed at the wrong time.
Possible Causes:
Ignition on or engine started. The PCM received a message over the CCD Bus from the Transmission Control Module (TCM) that it had detected a problem and set a trouble code in memory.
Possible Causes:
