This is the Sabbath feature on my Kenmore Elite Electric Slide in Range. My oven manual says to press both the (timed oven) "cook time" button and the "delay start" button at the same time for approx. 3 seconds and this should shut down the feature. I had the same problem, tried the above and it worked.
didn't work
Worked for me! Thanks!
Thanks it worked.
Thanks so much, it worked
Hello & Welcome to FixYa
5A6 or SA6 or SAB is not a error code and is displayed when the unit is set up to Sabbath mode. To reset this error code you can press and hould the CLOCK pad which is located below the display for around 15 seconds. If the problem returns then it is recommended to leave the unit unplugged for 72 hrs so that the problem is solved. Please get back to me if you have any other questions.
Kevin
Perfect!!! 15 second hold of CLOCK worked just fine. Thank you!!!
didnt work
didnt work too..
I solved by press and hold both the (Bake time) and (Start time) pads for at least 3 seconds.
This works for my model PLGS389ECJ.
Good Luck.
LENNY C.
