when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Some Brinkman grills have the LP orifice installed on the NG orifice directly from the factory.
If that is true, you remove the LP orifice and the NG orifice is already there. Check instructions in the conversion kit and look for this detail carefully. I just did a Brinkman conversion and instructions were very confusing. The orifices in the kit are not used (on my unit).
If you have a high pressure 2lb LP Gas System feeding your house, you will need and inline regulator for you grill.
If you have Natural Gas, the grill will have to be converted to Natural Gas. You can do this by changing burner orifices. You can purchase them from Brinkman. That is, if Brinkman approves the change to Natural Gas. Some gas grills aren't convertible.
