Hello, my dishwasher gorenje pms 60 l show specific faulty code. Both LED blinking symmetrically. Serviceman doesnt know. Please help me with this problem. Thanx.
Well your all brilliant. Point 1. The filer in the bottom of the machine was full of Cra* once I cleaned out the filter, pulled the integrated machine away from the wall and (Point 2) tilted it on its back legs (you were right about the mess - as more water came out) the E4 signal went. Im just trying it now so will come back if the machine doesnt work!! Thanks for the advice!
SOURCE: dishwasher is flashing error code
"E4" code relates to the overflow detector There appears to be an internal sump. Lean the machine back about 35-45 degrees to remove the excess water from the dishwasher. It might be messy so be prepared. By design the sump collects water from condensation i.e. (Cold outside machine wall, hot inside machine wall) hence condensation builds up and is suppose to and should evaporate in the right environment. Placement and installation locations play into a big part of the design.
You will notice by observation just in the centre there is a polystyrene float. This is what activates the overflow switch which throws the error code.
This probelm is simple to fix, just take off your kitchen plinth and turn off the dish washer power. then at the base of the dishwasher there are 2 plastic clip access panels, take a blunt screw driver or knive to help you ease out the plastic panel. once this is off, simple take a dish cloth out mop out the water, particularly from the left hand side as this is where the sensor is. Once dry (ish) replace the panels and switch on - DONE! its that easy
SOURCE: Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
SOURCE: Whirlpool dishwasher Fault codes
Fault code related to Flow meter. Cleaned the connections and reconnected.It worked fine for 2 weeks and failed again.Replaced the water chamber which contains the flow meter and the issue is resolved. The water chamber cost me 87euro including postage from Quinnspares in Co.Derry Ireland.
